I can help you
send me pm
your mailbox is full
I can help you
send me pm
WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
Fileservice
no thanks no pass
Ok Mailbox is cleaned
Post original file in thread" Free tuningfiles" better than via PM, and other members can see files and tell is it ok, what to change, we are here to share experience, not to compete each other, regards.
betrescudan (11th July, 2014), hcsaibot (11th July, 2014)
Baddog84...can you make the map mod without password................?or are you affraid by critics?
Thank you mates for your answears
Im waiting for my mpps, when i have it i will post the org. file here
Are you sure? Its a EDC15
But soldering should no problem by me
mpps must work without probblems...for reading full flash,use programmer....mpps read partialy (only parts of maps and little more...can,n use for make backup full of ecu)
You have option in MPPS to read full ecu data or just map contain, for some cars MPPS read only maps data for exampe BMW dde3.0 read only map 32kb, but some other ECU, MPPS read all data, you have option in menu what to do, read full data or just partial, regards.
Just buy MPPS it will work perfect on this ECU.
You have right,
ECU is MSA15
038906018AR
SW 1820
BOSCH # 0 281 001 728
Have you a tuning file?
EDIT:
Orgi**** File
Audi A3 ALH 1.9TDI_90PS_1997_038906018AR_Bosch-MSA15_ 0281001728.zip
