    seba_m_'s Avatar
    Default Saab 9-5 1.9 150HP DPF off help
    It will help someone to remove the DPF, I tried Volta and EcuSafe but it does not work well. The car is a SAAB 9-5 1.9 150HP EDC16c39 Thanks.
    Apr 2012
    Wonderland
    try with fiat solution...it's alfa 159 engine/ecu combo.
    both volta and ecusafe do the job
    ProTuner since 1999
    seba_m_'s Avatar
    Quote Originally Posted by atomiczen View Post
    I did as you write, the car smokes excessively and has increased combustion.
    DK Veteran velindro's Avatar
    Portugal
    Default saab
    try and report,but should be OK
  5. The Following User Says Thank You to velindro For This Useful Post:
    seba_m_ (11th July, 2014)
    seba_m_'s Avatar
    Quote Originally Posted by velindro View Post
    Thanks to my friend, just check and give a report.
    seba_m_'s Avatar
    good work, thanks
