    mariusica_boy's Avatar
    Default Mercedes Sprinter need DPF off
    Hi friend! I have Sprinter without DPF (its damage). I need help of remove DPF in ECU
    ECU Soft 1037391213
    File read of MPPS
    With Volta ecusafe dont work !!!
    Thank you in advanced.
    Germany
    Dump DPF off ,disconnect connector from temperatur sensof and sensor diff.pressure. Pass PM
    best regards Eddy
    Jun 2009
    Hi!Can you help me to remove dpf on this ecu sw1037381071 its from Sprinter 311cdi
    Please!!!
  4. The Following User Says Thank You to altera For This Useful Post:
    vagdiag0com (10th May, 2018)
    Aug 2012
    LATVIA
    this is program solution..
    Jun 2009
    I do not understand ...... this is original file
    Germany
    Hi Altera
    you file DPF off ,disconnect connector from temperatur sensof and sensor diff.pressure. Pass PM
    best regards Eddy
  8. The Following User Says Thank You to 16eddi67 For This Useful Post:
    altera (15th July, 2014)
