Results 1 to 14 of 14
    Default Mercedes Vito 1037383382 dpf delete now no start
    Hi have a Vito read ecu via obd deleted DPF corrected checksumm and flashed back
    now vito doesnt crank i still have comms with ECU no fault codes stored
    I have pulled full BDM can anyone check it or have an ori i can check incase my original read is at fault
    Woody
    Does anyone have full bdm for this
    Ok defo need ori to patch my bdm read back to working can anyone help
    I can fix it if u givei initial OBD original read. and current BDm read
  5. The Following User Says Thank You to ominimicu For This Useful Post:
    woodysjw (12th July, 2014)
    Thanks a million here they are
    Fantomisback's Avatar
    Aug 2012
    Quote Originally Posted by woodysjw View Post
    u can try this bdm file write all
    Ok will try it now will this retain my immo data
    I get an error in rar file
  10. #9
    Aug 2012
    Europe
    i try your rar is ok
  11. #10
    Yes sorted Rar flashed file still no go I read out flash after writing your file and it seems half the flash is empty
  12. #11
    Still no start
  13. #12
    Babos's Avatar
    Mar 2012
    Maybe you brocken ecu when open him?
    Try take used ecu and write full and check.
  14. #13
    I got van to crank started once but then won't start again like bad checksum I used a hex editor and copied my part obd read into my bdm read
  15. #14
    Can anyone check this to see if its a full BDM read flash
