Results 1 to 8 of 8
    Default VW Tiguan EDC 17 CP14 DPF remove...HELP
    hello my frend i need help for remove DPF in this fille I READ it with mpps v12
    thanx in advance
    and you're not going to be able to write it back....
    Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
  3. The Following User Says Thank You to J_amb_o For This Useful Post:
    NOUNOU1212 (20th February, 2015)
    mastaflex's Avatar
    Jan 2009
    FR47310
    cheap and shit tools, playing with hard ecu's, want free moded map, broke the job, don't want to invest in pro tools.....
    i have galito 2 is it usufull? can i use it to read edc17cp14 ?
    mastaflex's Avatar
    Jan 2009
    FR47310
    try and tell us
    DK Veteran daniel guerra's Avatar
    Yes you can and it works!
  8. The Following User Says Thank You to daniel guerra For This Useful Post:
  9. #7
    HI frend any help pliz
  10. #8
    Sep 2014
    Better don't start work with ecu's like edc17 if you don't know how.
    You will not be able to write back moded file with obd mpps, if ecu has tprot
    Use galletto, simply, read a boot mode pdf which you have.
