Yes :-) Thanks. Just found a working version 1.3.3.2.
Also I had to have the network connected. Thought it was an option.
Good forum - THANKS GUYS!!
Almost went NUTS over this ;-)
My dreambox is dead.
I want to flash with dreamup.
No problem with connection.
I click on connect then power on the DM
Dreamup uploads the flash but stays at upload completed, waiting for acknowledge.
Changing cable or dreamup version didn't change the result.
What can I do?
Thank you
I have the same problem on DM600, it just sits there waiting for an acknowledgement. Restarting it does not solve the problem.
Required
- Null Modem Cable (this is NOT the same as a serial or rs232 cable, although it looks the same)
- Image File (.img)
- DreamUp Program
Please can someone explain to me what is an 'image file' and where I can get/download this? Thank you very much
Is anyone out there with a solution for the timebomb with ver. 4.3.1 and above. I?m having problems with my dm500S.
Thanks anyone for replying!
The image file is the "operating system" that you need to use the box, like windows on a pc.
As on pc`s there are many different, and you need to try different to find out what you like.
But basically, everyone does the same, but with different skins/look.
You also need to download and install cam`s, this is a small "programm" that you need to read cards etc...
Hope this was helpful![]()
reading of the posts and reply is of great help,thannks for all![]()
I use dream up 1.3.3.4 to flash 3 dm600.
The first 2 flashed normally but the third when I connect the power the program recognize the dm600 but nothing else happening...
ive done this today!
thanks!
Wher can i download dreamup older version ?latest version 1.3.3.5 is not working correct![]()
my dream box reciver is blocked no channels shown, what can I do to see all channels, OSN, Sky channels...etc....
help, im getting upload error when i try to flash using dreamup.
