Page 8 of 15 FirstFirst ... 345678910111213 ... LastLast
Results 106 to 120 of 218
  1. #106
    Top Poster domirudi's Avatar
    europe
    can anybody help me with my problem in db 500s?
    when i mount a new image i use dreamup with null modem cable.
    it said to me
    ping result ok,box is alive adn speaking to us.
    at the end said flashed sucessfully.
    at reboot it doesnt give a signal and doesnt respond on remote ,or button near green led.after reboot green led stay on and doesnt change.
    can anybody help me please????
    Is dead my dreambox 500?
    how can i repair it?
  2. #107
    europe
    anything to suggest for my problem??????
  3. #108
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by domirudi View Post
    it said to me
    It might be a bad flash reflash it again, if it's still the same use a different image and different version of dreamup.
  4. #109
    Sep 2010
    Se puede hacerlo con cable USB ? Gracias.
  5. #110
    Sep 2010
    Hi!
    I have a problem with my DM800.
    When i use DreamUp it stops on the command "upload completed,waiting for acknowledge" every time i try..
    And the display shows: "Dream Multimedia ->error!
  6. #111
    Oct 2010
    I am new to the forum and hope I have got this correct. Just a shout to say when flashing dm600 with image and Dreamup , be sure to hold the power button while you apply the power cord. This will cause the bootloader to be copied to the box.
  7. #112
    Oct 2010
    London
    hey we've been trying to download the latest nabilosat image
    how do we do it ?
  8. #113
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by sidnaz View Post
    how do we do it ?
    How are you tryng to do it ?
  9. #114
    Oct 2010
    hi , can some one tell me how to get sky sports back on dreambox please
  10. #115
    Oct 2010
    Default hi
    hi , can some one help me out i ben trin to conect dreambox to dreamup but it wont conect i dont know why ?
  11. #116
    DK Veteran Grizz's Avatar
    Sep 2010
    Ireland
    Quote Originally Posted by vini76 View Post
    you need a null modem cable and a computer with a serial port (or a usb adaptor for cable), then follow Devilfishs' excellent guide on page one of this thread. if you still have a problem be a bit more specific and someone will help.
  12. #117
    Oct 2010
    Hi guys. I'm hoping you can help me.
    I have a DM500-S box that recently just sat there with the green led lit and didn't respond to any remote controls. Even after powering off and on, the usual yellow "GP" wasn't showing.
    I've been reading through the forums and piecing together what I have to do to fix it, but I'm stuck.
    I have gone through Dreamup and reflashed the box with pli-jade3. I've then used DCC to use the Addons button to put Ccam 2.1.4 on it.
    Now I'm stuck. What do I do next? Do I connect it up to the TV and start sat scans and creating bouquets? I have a friend who has given me a line. Where do I input this information?
    Thanks in advance.
  13. #118
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    http://www.digital-kaos.co.uk/forums...50/index3.html u can add channels with dreambox edit . will save u
    scanning
    1-DreamUP V1.3.2.1 NEW
    2-DreamBoxEdit V2.02 NEW
    3-Dreambox Control Center v2.95 NEW
    4-bitcontrol? MPEG-2 Decoder v2.1 NEW
    5-bitcontrol? Digital TV Link 2.9 NEW
    6-DVR-Studio Pro v1.56
    7-Screenshot Tool v1.72
    8-NFS Server v4.3 NEW
    9-TS Converter V2.5
    10.FLASHWIZARD v6.3
    http://rapidshare.com/files/42761846...Tools_v3.0.exe
  14. #119
    Oct 2010
    can't edit above...
    forgot to mention that whenever I connect with DCC, it reports "No BootManager Found". Is this something else I need to fix or just normal?
  15. #120
    Oct 2010
    Thanks for the link to the channels prog. VERY handy.
    However, I fear I'm back to the start again. My DM500S isn't responding to the remote or the button on the front. To top it all off, I can't get DreamUp to connect to it so that I can retry a different image.
    I'm stuck in a vicious circle.
    The amber leds that flash on the inside that I'm assuming show network connectivity... sometimes they will light but more often will not.
    If I do happen to get those leds to light. I then run Dreamup and it asks for the Dbox to be switched on, but because it doesn't respond, the only way to simulate this is to pull the power lead from the back and plug it back in. At this point the leds will not light again because of a power loss.
    There is the green progress bar moving along and "uploads flash-loader", then "upload completed, awaiting acknowledge". And that's where it stays.
    On the previous attempt at flashing my Dbox (when I made my 1st post) it went straight onto another progress bar and said it was communicating with the box.
    I've tried Flash Wizard, but again, it's looking for an ip, and the box seems very temperamental about network connectivity.
    Is my 500S a write off, or are there other things I could try to resurrect it?
    Thanks in advance.
