Hi Guys, I'm having problems getting Mighty channels to work on my PAL Wii. I have some NTSC N64 wads that I want to run using Mighty Channel's option to force them to run at 480i , therefore getting 60Hz NTSC N64 games to output via RGB SCART which they won't usually do (you get only the red colour coming through if you run them from the Wii dashboard). This is done by using the Mighty Channels 'force 480i' setting. I've been told that this is possible.
Just to be clear, I'm not trying to make the N64 games region free as I have already done that. My aim is to force an NTSC game to output via RGB SCART at 480i. Usually NTSC VC N64 games only output via component or S-video. The reason for all this is to be able to play the games on my RGB SCART CRT TV. Mighty Channels has an option to do this.
I'm using Mighty Channel MOD Version 11.1
I dumped the NAND on the SD using simple FS dumper. I used cIOSX_rev21-Installer and already had the games on my Wii dashboard so didn't need to add them to the Nand on the SD. Saying this, to be sure, I tried again - this time deleting a wad (Mario tennis) from the SD NAND with showmiiwads and replacing it with a fresh wad - still no joy.
I haven't edited the Meta file - not sure if I need to?
My problem is that although I've got Mighty Channels up an running, when I attempt to load a game, I only get a black screen. I tried using Gecko os with the same result.
Is there either an easier way to do this (Force RGB SCART 480i output on NTSC games on a PAL console) or a way that I can get Mighty Channels to load my games without crashing?
Here's my system details:
Syscheck v2.1.0b19 by Double_A and R2-D2199, Nano
...runs on IOS58 (rev 6176)
Region: PAL
System Menu 4.3E (v514)
Priiloader installed
Drive date: 2007.02.13
Homebrew Channel 1.1.0 running on IOS58
HomebrewFilter ist nicht installiert
Hollywood v0x11
Console ID:117356188
Boot2 v4
Found 160 titles
Found 52 IOS on this console. 5 of them are a stub
IOS4 (rev 65280): Stub
IOS9 (rev 54321): Trucha bug
IOS10 (rev 768):Stub
IOS11 (rev 54321): Trunca Bug
IOS12 (rev 526): No Patches
IOS13 (rev1032): No Patches
IOS14(rev 1032) No Patches
IOS15 (rev 1032) No Patches
IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
IOS17 (rev 1032): No Patches
IOS20 (rev 54321):Trucha Bug
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 54321): Trucha bug
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev3608) No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev54321): Trucha bug, ES Identufy, NAND Access
IOS37 (rev5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 3072): Stub
IOS41 (rev3607): No Patches
IOS43 (rev3607): No Patches
IOS45 (rev 3607) :No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 54321): Truncha Bug
IOS51 (rev 4864): Stub
IOS52 (rev5888): Stub
IOS53 (rev 4113): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 54321): Trucha bug
IOS61 (rev 5662): No Patches
IOS70(rev 54321): No Patches
IOS80 (rev 54321): No Patches
IOS90 (rev 54321): No Patches
IOS202[60] (rev 65535, Info: hermes-5.1): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0)
IOS223[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0)
IOS224[37] (rev 65535, Info: hermes-v5.1):Trucha Bug, NAND Access, USB 2.0
IOS236 (rev54321): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS247[57] (rev 21006, info:d2x-v6):Trucha Bug, NAND Access, USB 2.0
IOS248[56] (rev 21006, info:d2x-v6):Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21006, info:d2x-v6):Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21006, info:d2x-v6):Trucha Bug, NAND Access, USB 2.0
IOS251[57] (rev 21006, info:d2x-v6):Trucha Bug, NAND Access, USB 2.0
IOS254 (rev 65281): BootMii
BC v6
MIOS v65535
Report generated on 2014/07/13
I would so appreciate it if anyone could help
Cheers, Andy
