Hy i have problem with peugeot Partner, i am getting this error time to time, and car goes into safe mode, can somebody know what could be problem?
P1198- injectors control; ECU internal fault
it looks like a fault in the ecu
Abrites ,full package
Carprog
Dajavue
Zedbull
orange 5
Tango
Vag-com
Vag Tacho
Vag Dash can
Vag Can pro
Magpro 2 X17/ FLEX
VVDI PROG /MB PROG
pay the price ...go original always works better......
p1198 - fuel presure- low fuel level
it's better tell us what peugeot partner is.
Did the injectors got disconnected while the engine was running? Or cranking? That usually fries the ECU, could be the cause of that error code.
M8,
Check wiring loom of the ecu, especially the ground cable from battery to chasis.
Regards.
please tell us what engine there's under the bonnet.
Some Pugs are famous to have short lasting injectors.
28000 km WTF
By the way do not replace injector: You have to verify that every injector isn't shorted.
Then you have to check wirings from injectors to ecu, and if there aren't other silly electrical parts in the suppl rail of the injector then you can suspect it's the ecu.
I got the very last Golf (mkIII of course), it has 1 injector 22yrs 260000km still original.
Let's play with math: how many Pug injector do I need to reach 260000km?
260000/28000 = 9.28 -----> I need 10 injectors.
Are car manufacturer selling jokes or not?
