Results 1 to 15 of 15
    west mids, uk
    Default HELP transit 2008
    This transit 2.4 TDCi, after 2 or 3 days, it will start after lots of cranking, and will then run if you hold throttle open, if let it idle cuts out and wont start for a few more days.
    Have good fuel pressure, put new crank sensor and cam sensor, programmed another ecu, and still the same.
    Also bypassed engine management relay.
    Fault codes are main relay de energised too early and main relay energised too late.
    This has 2 batteries and when I stop cranking it leaves the ign lights on the dash, but if i run on easy start, when the engine dies the dash goes off with a relay click from behind the batteries under drivers seat.
    Can anyone shed any light on what might be the problem here.
    Thanks in advance for any info, ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
    west mids, uk
    looking at live data, cam/crank sync keeps switching from yes to no when cranking, checked flywheel too but looks ok, checked crank sensor signal and is good wave.
    I think this one needs a bucket of petrol and a match....................
    ninja
  3. The Following User Says Thank You to ninja123 For This Useful Post:
    ollync (23rd January, 2017)
    Dec 2012
    EU
    Quote Originally Posted by ninja123 View Post
    ninja
    (cam/crank sync keeps switching from yes to no when cranking)
    this is normal i see this on working vans.
    Dec 2012
    EU
    i ring my body that works in ford dealer to see what he thinks ,and he thinks them dtc is not your problem ,he see van with them dtc running perfect.
    he said block off egr common problem.
    west mids, uk
    If egr is at fault then I will have various fault codes, done hundreds like that, but this van has no egr related faults, and also the top miles display changes to '-----' when faulty.
    thanks for your assistance, ninja
    west mids, uk
    previous garage changed rail sensor and flow reg in pump.
    ninja
    Meat-Head's Avatar
    There's a rumor on the toilet door down the pub, says 'PCM update at stealer '
    apart from that just regular rude words about Vic
    Dec 2012
    EU
    i will be there tomorrow in ford will get some info for you,i never seen one with this problem,but maybe they had one.
  10. The Following User Says Thank You to gttuning For This Useful Post:
    ninja123 (17th July, 2014)
  11. #9
    west mids, uk
    already been to ford when it was running, had pcm update then broke down 2 weeks later.
    Thanks for your help, ninja
  12. #10
    Meat-Head's Avatar
    Has it ever been stuffed?
  13. #11
    Dec 2012
    EU
    guys in ford had a transit in today for some repair and had dtc main relay de energised too early and main relay energised too late. and van still going ok,but they had two vans in past mileage blinking van no start and it was down to clocks.
  14. The Following User Says Thank You to gttuning For This Useful Post:
    ninja123 (18th July, 2014)
  15. #12
    west mids, uk
    got IDS on it today, there is a 5 second crank test and it is saying no signal from crank sensor, did same test 5 times, 4 times says no crank signal, 1 time say CAM sensor no signal, DTC for CAM sensor signal staying high.
    Got it to run first thing this morning after leaving it for 2 days, hold revs on and it ran for 10 mins, let it idle and after 1 min it cut out, cant get it to start again, also, when trying to run on easy start there is no rpm counter movement on dash.
    Why when left for 2 days does it run for 1 start then nothing?
    Had OE crank and cam sensors too.
    Tried a set of clocks and still the same, checked multi plug under ecu and all ok.
    Anymore ideas?
    Thanks, ninja
  16. #13
    west mids, uk
    TRANSIT IS FIXED!!
    I was testing the loom and found high resistance on one of the crank sensor wires, re wired and got a runner.
    BUT, why was there never a fault code stored for 'crank sensor circuit' ?? Surely the ecu tests the resistance across the crank sensor when ign is turned on?
    Anyone know why this was the case, took bloody ages to solve as was reluctant to test loom due to lack of fault codes for that area.
    ninja
  17. #14
    Meat-Head's Avatar
    Because it was high resistance it proberbly could see curcuit but was thingking
    you was not cranking just sat with ugh in, clips do that
  18. #15
    west mids, uk
    Its not the diag tool meaty, I had 5 different types of tool on it, never did it show any faults relating to crank sensor circuit, but the ecu should measure resistance across the sensor and if its out of range then a DTC should be set, i tested at ecu plug and was completely open circuit - f*****g thing.
    ninja
