Results 1 to 3 of 3
    DK Veteran mathura's Avatar
    Aug 2011
    Default Probelm with CAT 980H ECM
    I need your help with this problem, Cat 980H wheel loader SN MGH00880.
    I have flashed a new ecm for the implement control. It said that ECM successfully flashed. I then clicked return to ET.
    When ET connected to the ECM I get this message
    "Unable to find exact match for the implement control software version found in the ECM. The integrity of changed parameters and data is not guaranteed. Click OK to continue"
    When I clicked ok the following information is displayed
    ECM Part Number 172-9391
    ECM Serial Number 3018B296DL
    Software part number 3665447
    Software date AUG 2010
    Software Group 980H IMPLEMENT CONTROL
    Active diagnostic present ERROR retrieving active codes
    ECM location Code Unavailable
    Desired ECM location code Unavailable
    When I go to configuration all that is displayed are:
    ECM ID PARAMETERS
    Product ID MGH00880
    Equipment ID unavailable
    Nothing else is displayed in this area
    Please can someone give me some suggestions what I can do. I blanked ECM and tried another flash file 328-2844 that I got from a member here but the result was the same.
    Oct 2015
    Quote Originally Posted by mathura View Post
    ECM ID PARAMETERS
    Product ID MGH00880
    Show me the full machine serial number
    Apr 2011
    Default MGH00880
    Dear Friend
    Pl,can you provide correct serial no and prefix,As per your prefix MGH 00880 not a Wheel Loader
    Once again check the old configuration and flash file no
    Greeting's
