Results 1 to 8 of 8
Hybrid View
    88diablo's Avatar
    Default EGR delete in VAG 1.9 tdi please.
    Hi all, just put an EGR blank plate on my VW Caddy 1.9 TDI 2008 van and its showing EGR fault code all the time. Could somebody delete the EGR from the map please and also being cheeky give it a bhp tweek but keeping economy in m ind too please so not too major. File read with a Powergate.Thanks in advance
    Fec001's Avatar
    Default egr off
    This should work!
  3. The Following User Says Thank You to Fec001 For This Useful Post:
    88diablo (17th July, 2014)
    NASTASE's Avatar
    ROMANIA
    Hi 88diablo,
    saw your posts,you have a good contribution on DK,here is your file with EGR off and +25HP.Pass in pm.
    Real engines don't need forced induction
    Who needs a turbo when you have a stupidly quick naturally aspirated engine?
  5. The Following User Says Thank You to NASTASE For This Useful Post:
  6. #4
    88diablo's Avatar
    Ok thanks I'll try when I get home later and report.
    88diablo's Avatar
    Thanks to you too Nastase, I'll play now when I'm home.
  8. #6
    88diablo's Avatar
    Just done 60 mile trip on first and then 60 mile back on 2nd, both pull much better and make van much more drivable. EGR fault didn't appear on either so very pleased. Thanks again to you both.
  9. #7
    Top Poster automocion's Avatar
    Jun 2013
    Iberia
    How about fuel economy on remap file, its more or less?
    Enviado desde mi iPhone con Tapatalk
  10. #8
    88diablo's Avatar
    Just looking at MFD display whilst driving both files looked similar to standard but 60 miles is not enough to test and I was playing with the turbo more due to better acceleration etc so if it looked the same but I was driving harder there probably was an improvement. With it driving much better though so long as it doesn't use more fuel I'm not bothered about an improvement now to be honest. I plan to leave 1 map in a month though and measure mileage over actual fuel used then swap maps for another month, do the same and decide which to run.
