Results 1 to 10 of 10
    blackpirate's Avatar
    Jun 2009
    Default golf 6 pcr 2.1 eep file req
    hey guys anybopdy by mistake can give a hand with this eeprom content
    24c640 03L906023ML
    need only eeprom not flash!
    thnx in advance
    cheers
    BP
    If freedom is outlawed, only outlaws will have freedom!!!!
    Jun 2013
    EU
    Hello.
    Here PCR eeprom, locked and unlocked.
    Regards,
  3. The Following 2 Users Say Thank You to morgano For This Useful Post:
    blackpirate (18th July, 2014), masterb (18th July, 2014)
    ahadi's Avatar
    can you extract immo details from eeprom ?
    Jun 2009
    @morgano thnx, i will report when my friend try it in ecu and try to adapt ecu on car on dealer
    @ahadi
    srry i dont know
    Jun 2009
    update: issues are still there
    looks like i need flash+eeprom file from the same ecu!!!
    anybody else????
    cheers
    Nov 2011
    friend and friend
    Default hello
    I only have this, see if you can serve
    Monday I can see if I have in the lab, I think so.
    do remember and I will send
  8. The Following 2 Users Say Thank You to arvedo For This Useful Post:
    blackpirate (20th July, 2014), BusCan (11th June, 2021)
  9. #7
    carmageddon's Avatar
    Italy
    Quote Originally Posted by blackpirate View Post
    anybody else????
    cheers
    which SW VAG you have on your ecu?
    i have this version, maybe can help you
    5WP42902AA_03L906023ML_9052_SM2G0LD000000.zip
  10. The Following User Says Thank You to carmageddon For This Useful Post:
  11. #8
    here
    this 2 eeprom from pcr2.1 one from golf & one from audi,good luck
  12. The Following User Says Thank You to smt For This Useful Post:
  13. #9
    the immodata is in flash, i think there is no tool yet which can read the whole flash, incl immo block , the most read just the remap part.
  14. The Following User Says Thank You to chriskross For This Useful Post:
  15. #10
    ahadi's Avatar
    maybe in the flash is only power class , immo data is in eeprom.
