Results 16 to 30 of 43
  1. #16
    Nov 2013
    you can use used 8e key
    but youcannot use new 8e chip
    i have eprom dump and flash from immo (freescale inside)
    you can use key from new daewoo gentra (uzbekistan)
    you can make immo off on sim-2k d52 and sim 2k243
    for last ecu you need boot mode tricore
    for d 52 DSL mode
    (LMT LMU LKY engines)
  2. #17
    Nov 2013
    this eprom and flash from immo
  3. The Following User Says Thank You to djal For This Useful Post:
    n599fbm (16th January, 2015)
  4. #18
    Nov 2013
  5. The Following User Says Thank You to djal For This Useful Post:
    kyawkyaw (26th December, 2015)
  6. #19
    Aug 2010
    Australia
    Thanks for this info. Do you mean we can use used 2nd 8E chip from other daewoo keys or Do you mean any used 8E key? I assume it should be Daewoo used 8E key
  7. #20
    Nov 2013
    yes / daewoo or chevrolet 8e used . you can use mdi or other device
    chevrolet spark m300/ (matiz creative) daewoo gentra (uzbekiastan)2013
    i have locked 5-6 new 8e/ i tryed prepare it by myself
  8. #21
    Nov 2013
    do you have ECU picture?
    i can help make -noimmo
  9. #22
    Nov 2013
    much keys stop working
    uzbekistan . russia . ukraina have same problem / keys -dead
  10. #23
    May 2011
    Hungary
    Solution:
    Launch X431 MASTER
    GM software :
    Immobilisier, All keys lost function
    Regards,
  11. #24
    or x100 got this sync option
  12. #25
    west mids, uk
    still need data to precode 8e or will not work.
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  13. #26
    garagetech's Avatar
    Oct 2008
    Quote Originally Posted by zzz28 View Post
    Solution:
    Launch X431 MASTER
    GM software :
    Regards,
    I believe we still need to precode transponder before or can x431 handle this with all lost key option through obd?
  14. #27
    Done 1 today, 2011 Spark. Car had been parked for around 4 months and immo light flashing with both keys. Managed to connect using T100, normal OBD Cable under Matiz 2
  15. #28
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    Quote Originally Posted by kevfield View Post
    Ok programming key is the easy bit but precoding you are saying cant be done ??? so what your saying is that the only way to do this key is to buy precoded key from dealer and program
    Thanks kev
    ..........yes
    I am a FUD
  16. #29
    kevfield's Avatar
    uk
    Quote Originally Posted by obdsystems View Post
    ..........yes
    Yeah mate this is old news to me , i posted this in 2014 ...
    Thanks Kev
  17. #30
    Quote Originally Posted by gurmk View Post
    Customer gone to car this morning and no start immo light flashing again. Will check and report.
