Page 3 of 3 FirstFirst 123
Results 31 to 43 of 43
  1. #31
    gepakg's Avatar
    Serbia
    8E transponder have 12 bytes secret key which must be pre-coded for each car or programming can`t be done
    bit same as a6l/q7 etc...
    regards Gepa
    Quote Originally Posted by gurmk View Post
    Customer gone to car this morning and no start immo light flashing again. Will check and report.
  2. The Following 3 Users Say Thank You to gepakg For This Useful Post:
    doctore (2nd March, 2017), gurmk (5th March, 2017), lion0304 (1st September, 2017)
  3. #32
    Nov 2015
    which device can read this immobilizer on bench?
  4. #33
    castin's Avatar
    Oct 2015
    SKP1000 program this chip. Im try used key (8E) from other spark and program it OK, car start .
  5. The Following User Says Thank You to castin For This Useful Post:
    Faraday (1st June, 2022)
  6. #34
    PierreTheron's Avatar
    Centurion,South Africa
    hi
    Anyone got the pre coding data for these please .
    I always use secondhand key and it programs in but the much meed precoding data is locked..
  7. #35
    daniersms's Avatar
    South Africa
    Default spark
    Here it is
    Love this forum
  8. The Following 3 Users Say Thank You to daniersms For This Useful Post:
    fred77 (17th October, 2020), just4upal (13th April, 2019), whiskeyman (9th October, 2019)
  9. #36
    I tried , precoded Via Tango and programmed success with T-300
  10. #37
    Managed it this way .
    Programmed secondhand chev 8e key to vehicle .
    Then cloned it with vvdi keytool to an vw 8E transponder
    Car is a runner ...... with the cloned chip..
  11. #38
    South Africa
    Customer bought new reader with two keys ,having a problem marrying ecu to new reader, ecu siemens D42, any ideas?
    Do what you can with what you have .
  12. #39
    South Africa
    Not needed anymore ,just did immo off , pm me if you need file
  13. #40
    May 2020
    hello, so if I precode a new 8e with this data,it will be possible to add it to Chev Spark?
  14. #41
    Nov 2016
    Hello.
    Some update for future:
    Advanced Code Evo / Miraclone can precode blank 8E.
    Chip locked after precoding.
    Than Obdstar X300 DP can program by obd.
    There is only function "all keys lost". Need 2 keys to program.
    Doesn't matter if adding spare key or no working key present.
    2 keys need to be programmed one by one.
    End of story. 5 minutes job. Good luck.
  15. #42
    Jul 2015
    Hello, what option did you choose for programming key for this car? Chevrolet Spark or Daewoo Matiz?
  16. #43
    Jul 2015
    Quote Originally Posted by carkeyfix View Post
    Hello.
