Results 1 to 8 of 8
    Junior Member codipa's Avatar
    Jan 2012
    Default RENAULT - LAUNCH X431 - KEY PROGRAMMING
    HELLO FRIENDS.
    HAVE A PROBLEM WITH CODING KEYS OF A RENAULT SCENIC 2.0 16V 2001
    SIRIUS 32 - Y HAVE THE CODE 8 DIGITS .
    'M TRYING TO SET THE KEYS TO A LAUNCH 431,
    I AM NOT GETTING THE CAR RELEASE.
    WOULD LIKE TO KNOW IF SOMEONE KNOWS THE STEPS, for coding KEY, USING THE LAUNCH X431.
    Nov 2010
    Renualt has 12 digit pin
    Jan 2012
    SCENIC 2001 - 8 DIGITS COD
    Jun 2012
    Yes 8 digits .sbb or mvp or t300.......
    Feb 2013
    If u have code 8 digit u can do this with launch but u must sure u input the code with cabslock write
    Jan 2012
    Friend MANASRAH , please explain better, a little closer
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Newest Launch X431 software skips the code.
    He says you need to input code in ALL CAPITAL LETTERS.
  8. The Following User Says Thank You to simaservis1108 For This Useful Post:
    manasrah (22nd July, 2014)
    Jan 2012
    asks the code that is in numbers - 8 numbers
