Hi mate,
Your EGR off by switch.WinOLS (1499.rar
Hi mate,
Real engines don't need forced induction
Who needs a turbo when you have a stupidly quick naturally aspirated engine?
after flashing there are errors
P1643 in DDE
P1844 in TCM
with the original there are no errors
Hi mate,About Fault codes-
First-P1643-This Fault Code is only a Note referring to relevant Fault Codes stored in another Control Module
Second-Fault code on TCM-transmission
- e /
- Land Rover /
- OBDII Fault Code P1844
Land Rover
P1844: OBDII Land Rover Fault Code - Manufacturer Specific
System: Body
Sub-system: Transmission Controls
P1844 - Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Battery
So, no conection with EGR off,have changed only one bit in ECU.
Check your Transfer CaseDifferential Lock-Up switch.
car came with no errors.
P1643 in DDE
P1844 in TCM
after flashing original flash
errors disappeared again
somebody can help me?
Hi if you make egr-off by swich, you need umpluged egr, or solenoid egr.
