after u get a DPF off file from any of the members. check to see if Cruise control will still work after
thanks for the info I hope that some users try to help me
I can help you with 100% good solution with all working. Only without dpf. If you need professional solution write me on PM.
guys thank all those who have spoken, I resolved, I bought a file from a no fap Italian tuner, so I can converse more easily. thanks again to all
from where did you buyed ?...i need a box with 5 kg solution for my tuning futures files---
Cruise control work?after dpf off
Can i have the working file please ? its for me mate you see..
Sisco please check to see if your Cruise control still works, it it afected by the regenration maps during cruise. You may find it Not working P
welcomeback my friend ominimicu
I can make 100% working file. Tested on real cars by myself.
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
