    Default Jumper edc16c39 dpf problem
    Hi all,
    i?ve done this jumper 0281015684 3,0 hdi dpf-off by switch, car is working fine, no more problems, but has DTC and MIL on. DTC?s are: P2002, P2081, P2085. I dont know how to erase dtc tables. Can anyone help me on this, please?
    Here are the original and edited files, readed by bdm.
    carmageddon's Avatar
    Italy
    you can not do dpf off by switch, dont work, and this 3 dtc are present because dpf off is not correct
    Thanx for very fast answer! And how to solve dtc-s? I will not play with volta, or ecusafe...
    Italy
    only with damos and tests you can solve dpf off problem
    report eventual dtc ,pass pm
  6. The Following User Says Thank You to pinotec For This Useful Post:
    IwanNIS (23rd July, 2014)
    Hi.Try and send result.
  8. The Following User Says Thank You to nikka For This Useful Post:
