Results 1 to 9 of 9
    Nov 2010
    Default NEC Programmer ,,RECEIVER TIMEOUT ERROR,,
    I bought this programmer(kaufen NEC Programmer Kfz-Werkzeuge Online G?nstige Preise Deutschland) tried on two pc and does not work
    Message: RECEIVER TIMEOUT ERROR.
    Do you have any solution for this defect
    Dec 2009
    Serbia
    Quote Originally Posted by Repinator View Post
    Did you put 12v power? What you try to read?
    Nov 2010
    yes is powered by 12v
    I tried not to read anything
    software does not recognize the programmer
    appears the message RECEIVER TIMEOUT ERROR
    normally must appear NEK Programmer Ver. xxx..
    Nov 2009
    serbia
    check com port settings, check cable between pc and programmer.
    Jan 2020
    Hi! I have exactly the same problem. Is there any solution?
    Thank you!
    Enviado desde mi ELE-L29 mediante Tapatalk
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    anybody can share a solution on these red nec programmer with receiver time out error
    'If I helped, please click Thanks +Reputation.. !'
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Give pic of board.
    IF I HELPED YOU PRESS THE " T " BUTTON
    May 2015
    My Tool Room
    Quote Originally Posted by PSAcars View Post
    I am using Rs232 to usb converter cable
    May 2015
    My Tool Room
    any advice appreciated
