So clone BDM100 can be used with both CMD and DIMSport software without replacing eeprom content?
Hi. I'm also the same problem. I have Windows XP and is powered at 12 volts but I can not work. I tried with 2 different units. Pongo image error.
Greetings.
Last edited by alclot; 19th January, 2011 at 01:39 PM. Reason: I have Windows XP and is powered at 12 volts but I can not work.
I have not tried with any unit. Just does not connect because at least I would have to give communication and the relay to operate. I tested with 2 bdm different and do not work. If it works with another bmd that I have but it's Alientech. This problem alone makes me the BDM100 that are "CMD". Why may be? "Drivers?
Hello all today I got BDM100 but soft have worm. Do you know any body link for it pleas?
hello i purchase clone bdm 100 and triad on Suzuki_Magneti_Marelli_MJD ecm do like this connection but all time this erorVer. 3.1.0.1255 Dongle ID: 192 Date: 2010-03-23 03:34:17Firmware Revision V.01 SN: 0258+12Vcc power error or Communication error any solution please
HI,
so can anyone recommend hardware that actualy works.
Mine does the same..
Ver. 3.1.0.1255 Dongle ID: 192 Date: 14/02/2011 20:54:00
Interface Comunication Error
What is the problem?
I had same error, by me it was a defect on ECU, another ECU worked fine.
Or the wire connection ist not OK
mine is similar
Salut ? tous; mon probl?me c'est interface not found carr?ment. Peut ?tre est il tout simplement hors circuit....
Hi agan; excuse me for language...In english what i meant is: my 1236 interface say now: "interface not found".
It means that it's dead for sure or could i repair it?
What does this meassage mean?
Many thanks to all.
btw: is someone has a dump of HC11 of 1236 please? I ask tou that beacause i'm sure that 1255 is better but i know too that this1236 version is good...I'm a nostalgy man of this old version. So if it's the problem i will rewrite it.
