Page 4 of 4 FirstFirst 1234
Results 46 to 49 of 49
  1. #46
    Nov 2009
    London
    Pin 2 and 9 only have 12v on mine once you click the on button in the software ..
    i got mine a long time ago and it took me a while to get it up and running
    Try a decent 12v power source .. pretty certain i swapped out both the relays on mine and the transistors ..
  2. #47
    Apr 2020
    Yes but I put a wire to avoid the relay in order to have 12v on the ECU.
    Ok I will try to have a decent 12V
  3. #48
    Nov 2009
    London
    That might be your problem ..
    connect the bdm as suggested using a decent power supply.
    only put power to the BDM 100 not the ecu.
  4. #49
    Apr 2020
    My issue is still there.
    Even if I unplug the USB cable, I still see "communicaiton error".
    I think it's a driver problem or something like that.
    But i have no idea how to solve it...
    Do you have any solution?
