hi to all, have you any experience on common abs problem on mercedes ml w163 ate ecu.
The pump itself or the contacts for the pump, but they seems to be fine.
Hi all. I got a MK60 unit that hade the eccentric "drive bearing" rusted badly until complete blockage which also have caused the pistons to get stuck due due to corrosion.
After cleaning the rust away with a rotating steel brush, rinsing and lubing the bearing and coating the rusted parts and sloppy silicone gasket with marine grease, the motor is running fine, And no fault codes. BUT ESP/TCS is not working. Which is surprising when potentially importan safety system is not functioning at all.
Is there and chanse to free up the two pump pistons. Replace the seals and clean the opposite surface in the aluminium block so it will last worth doing a reconditioning job?
Or is buying a new or reconditioned unit the only safe option?
Cheers Gunnar
Sent fra min Moto G (5) Plus via Tapatalk
Som photos. Pump house before cleaning. And motor after cleaning..
i have mersedes w204 with esp problem of (5001 there is an internal fault in control unit n30/4) ... tried road test and checked abs wiring and connectors but all seems to be ok ... fault can be erased but comeback when vehicle reaches about 30 km/h ... here also a photo that may be helpful
wbr.
hi...
we have a broken ABS/DSC unit BMW E36/Z3 from 2002...
we found a used one, same part number...
when we built in, does we have to change VIN/coding like on VAG or something else...?
Yes you will have a dtc for incorrect vin and will need a tool to change this.
Sent from my H8216 using Tapatalk
figani (26th September, 2019)
Good Morning. I have this ABS drive mk60 € bmw E46 with error 5DF5. can someone help me with this
6759047 10.0960-0811.3
Enviado do meu Mi A2 Lite através do Tapatalk
I have a few dozen of these in the attic all with 5D5F or similar internal faults. Mostly with ABS only but the problem is the same. I would be very happy to know the cause of these faults.
My ABS MK60ec1 on Golf IV got 01130 error.
I resoldered all PIN at the side which is connected to ABS cable.
The error is still there.
How could I do next?
hi to all, how to solve this mk26 abs unit from mercedes with fault code 5001
Hi, here Laguna2 With ABS DTC DF185 Internal Supply Servo Solenoid active Valve Circuit...
any Idee...?
mohamed2007 (31st May, 2022)
