Page 19 of 21 FirstFirst ... 91415161718192021 LastLast
Results 271 to 285 of 303
  1. #271
    Sep 2019
    Is there anyone who could help me please, or direct me towards someone or somewhere else? Thanks
    Quote Originally Posted by guyc View Post
    Hello, I have a problem with my Subaru Outback MY2010 ABS/ESP-unit. Only today, I found this thread, but I started an own thread here:
    https://www.digital-kaos.co.uk/forums/showthread.php/839324-problem-with-EUDM-Subaru-MY-2010-ABS-ESP-how-to-reprogram-the-unit?p=3919986#post3919986
    Please would you be so kind to take a look there? Thanks, Guy
  2. #272
    italy
    Quote Originally Posted by Fuller View Post
    I need help with ABS ATE MK61 (1K0 907 379 AD) module with no communication from audi.
    I reflow BGA chip, resolder MCU and solder pins from chasis to PCB but I haven't tested yet.
    Is it enough to fix the fault?
    HI I'VE ATE MK 61 AS A PHOTO,
    MINE ONE HAVE ERROR 046A ABS OPERATION IMPLAUSIBILE SIGNAL.
    SOMEONE HAVE INFO FOR REPAIR IT?
  3. #273
    Oct 2017
    Removed the 0990 by masking and removing the middle of the chip w/ a burr grinder, it has a small metal pad soldered not glued to a large aluminum plate behind the PCB. Hot air station couldn't get enough heat to remove easily with reasonable heat flow. When putting it back tried thermal paste on the center pad and soldered legs under a microscope. No success was able to scan ABR for codes, but it had an internal error code current before it was just stored and could be cleared. Not sure if the center pad needs to be grounded, in that case you need to pull the PCB off the pins heat from the back and separate from aluminum plate. This is not easy. Perhaps you can press the solder button from the plate and put it aside. Then solder the new chip and use solder paste under the chip to attach the base at the PCB. Then solder the button and attach to the plate. seems to be a really bad design and vibration would break the chip legs over time or break the chip inside. In practice do you need to connect the center pad electrically to the PCB or can you use thermal paste on the center pad. Why the giant heat sink on that chip?
  4. #274
    Jun 2013
    Kikinda Serbia
    I played a bit with the CorsaD 1.2 ABS module in 2007. 0265950428.
    When opening the module, make sure that the fluid pressure sensor DOES NOT OPEN. When removing the plastic housing, the gold wires from the sensor to the electronics break. There are five gold wires (two are common) it is not a problem to replace them with copper. Pay attention to the layout of the wires. I will post a couple of pictures as I tried it.
  5. The Following 4 Users Say Thank You to RadovanPetkovic For This Useful Post:
    bearheroes (10th January, 2021), clauberty (15th March, 2024), Stelaras26 (3rd December, 2021), xseva (8th September, 2022)
  6. #275
    ...where was Columbus
    Default How to repair ABS system and units thread (repair,help,questions)
    Wow, that’s a big job you did!
    I appreciate for your sharing to us!
    Happy new year!
  7. #276
    Jun 2013
    Kikinda Serbia
    You can see an interesting video here, it is in Serbian and it will not be understandable. You can see how the solenoids and valves are tested. The test is not in real conditions because there is no oil pressure. Electronic testing only ....
  8. The Following 4 Users Say Thank You to RadovanPetkovic For This Useful Post:
    Ciri1990 (3rd August, 2022), MOBILTRONIC (20th November, 2022), NONO59 (23rd February, 2022), TR0UBLESH00TER (7th March, 2022)
  9. #277
    Feb 2016
    Hello! Please, give me a hint what is damaged in the ATE mk61 abs,
    I have errors 16352 control module and 01276 abs hydraulic control from time to time.
    vw jetta
    1K0 907 379 AD
    The installation has been checked and everything is fine.
    Thanks.
  10. #278
    Newbie Pawelpl's Avatar
    Jul 2019
    Quote Originally Posted by cubica1 View Post
    a little contribution from my self for all members. Audi A6 2005y, ABS unit repairing.
    rgds,
    cuby
    Was the repair due to error g201 (code 001435)?
  11. #279
    Agilechaveiros's Avatar
    Oct 2012
    Săo Paulo -SP -Brasil
    hello membos dk
    i need to repair ecu ABS jeep Cherokee with DTC 2200 someone with experience who can help me, thank you in advance
  12. #280
    Sep 2019
    Found a second hand ABS/ESP that fits my car, so my problem seems to be solved by now, otherwise I will be back here!
  13. #281
    dritan's Avatar
    Apr 2013
    Hello does anyone can help me how can I repair
    W169 steering sensor with hc08 MCU inside
  14. #282
    mexanico1971's Avatar
    portugal
    Quote Originally Posted by azza2 View Post
    My ABS MK60ec1 on Golf IV got 01130 error.
    I resoldered all PIN at the side which is connected to ABS cable.
    The error is still there.
    How could I do next?
    Do you soved ?
    BRs
    My work is my life ART TECH GARAGE
  15. #283
    Apr 2016
    france
    hi , i have ate mk70 ford ka 2005 with no communication, anyone have some info on this problem ?
    thank in advance
  16. #284
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Quote Originally Posted by doctorelectrical View Post
    Good Morning. I have this ABS drive mk60 € bmw E46 with error 5DF5. can someone help me with this
    6759047 10.0960-0811.3
    Enviado do meu Mi A2 Lite através do Tapatalk
    Quote Originally Posted by tomvleeuwen View Post
    I have a few dozen of these in the attic all with 5D5F or similar internal faults. Mostly with ABS only but the problem is the same. I would be very happy to know the cause of these faults.
    Sometimes it needs resoldering ALL contacts inside module, and if this does not work ,then resoldering MCU(I just use hot air gun) and drivers.
    Sometimes brake pressure sensors are the fault that get the 5d5f to show up.
    Sometimes rear wheel speed sensors are faulty even if they show speed.If you have a fault and 5D5F and a faulty sensor its probably related.5 out of 10,its the inside of the MCU that its the problem.Cannot solve it.I gave up after months of trying .
    If i Helped you,use thanks and rep button to thank me back
  17. #285
    ASCM's Avatar
    Oct 2018
    Hi does anyone can share solution for steering electronic module w205 gl etc thanks in advance
