Page 21 of 21 FirstFirst ... 11161718192021
Results 301 to 308 of 308
  1. #301
    alclot's Avatar
    Melee Island
    Hi mates,
    I need your help. I change ate renault abs to donor with similiar reference. Now abs works perfect but gets dtc C006A
    Can anyone help how to delete it? Maybe any configuration by diag.
    Thanks a lot
  2. The Following User Says Thank You to alclot For This Useful Post:
    McDowell (9th January, 2024)
  3. #302
    Aug 2019
    I have two Renault abs, one in a megane 2 and another in scenic 2 with C10C3 fault, does anyone know how to resolve this fault?
  4. #303
    Aug 2019
    did you solve the problem?
  5. #304
    Newbie sergiooo's Avatar
    Mar 2023
    Hi mates, i need your help to repair ABS unit Mazda CX-9 0265956483
    One of PCB components is missing after crash, i'm searching for good picture of board.
    It seems to be a diode, but i'm not sure. Thanx!
  6. #305
    Jul 2024
    Default I have the same problem
    Quote Originally Posted by TeiS View Post
    Hello
    I have a ABS from Renault Megane 3 with this dtcs:
    DTC505004 - Calculator
    DTC400201 - Calculator
    I see that there is not pump and solenoids activation.
    Mosfet for pump controller OK
    Dual diode from power supply OK and Mosfet and zenners OK but to this mosfet dont have gate voltage (controller by a 990-9413.1B)
    Also, in the +15 terminal i have two diodes, one of this, go to two resistors of 6800 ohm, one resistor is connected to ground directly and the other i dont know but is short to ground (rare...) (i dont know if this go to controller 990...).
    Someone have experience with this ABS? I dont know if is possible a problem with the 990-9413, i have comunication with the calculator....
    Has it been fixed? I have the same fault with the same error codes.
  7. #306
    Quote Originally Posted by dennisnt View Post
    No friend, I had to replace it. I have already rejected repairing ABS, in the ATE MK60 with VAG fault 01130, I have changed the 990-9413B, reballed the MCU, reflashed and they appear again the moment the vehicle starts running. I have used several methods to replace the 990 and in no way, in the end all the same result.
  8. #307
    Mar 2015
    I have a faulty ATE MK100 from a Volvo XC70 2007.
    Is it possible to transfer all needed data from this unit by transfer eeprom to another second hand unit?
    Or it it possible to make second hand unit virgin in any way?
  9. #308
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    does anyone know what transistor can i use to replace this one in bmw e39 DSC?
    because i tried with spot welding........And it was not a good idea :P :P
    If i Helped you,use thanks and rep button to thank me back
