Page 5 of 21 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 303
  1. #61
    jebo's Avatar
    DURIAN CITY
    Default BMW R1200GS I-ABS
    pls. see attached PDF
    ABS BrakeFaiulre.pdf
    ---NO to FEDEX/AIR21---
  2. The Following 26 Users Say Thank You to jebo For This Useful Post:
    alclot (6th March, 2018), amaflo (23rd August, 2017), armpower (11th May, 2015), Astrator (26th March, 2015), darka7 (14th February, 2023), dritindiag (3rd October, 2023), einet (6th March, 2015), gameiruz (5th October, 2016), gzaor (7th April, 2023), Hayssam1 (20th January, 2015), hbt (15th November, 2015), HDPTA (14th October, 2018), hector (12th February, 2015), insomnia2009 (21st November, 2014), janusz21 (23rd November, 2014), JFR-Tuning (23rd January, 2016), jmac200t (8th March, 2017), lagas (21st November, 2014), line44 (28th September, 2017), martinracing (22nd November, 2014), Matttes (14th January, 2017), mexanico1971 (21st November, 2014), rog3rio (26th December, 2014), TeiS (8th December, 2022), Torsen (11th November, 2019), xifly18 (11th December, 2015)
  3. #62
    soxten's Avatar
    Mar 2013
    Is it possible to get connections for pressure sensor?
    And, what oil channel is to sensor?
    I think it work over 5volt.
    I must try to connect a brakeheadcylindet to get pressure to sensor and mesure sensor.
    Christian Johansson via Iphone 5s
  4. #63
    DK Veteran thomas76's Avatar
    Oct 2010
    Most of the companies change just sensor, it is necessary to find where to buy them
    Electronic Automobile
    If post usefull press
    "THANKS"
  5. The Following User Says Thank You to thomas76 For This Useful Post:
    soxten (27th November, 2014)
  6. #64
    soxten's Avatar
    Mar 2013
    If some one has find a place to find this sensor please pm me!
  7. #65
    gomarota's Avatar
    Can anyone help me with this?
    abs peugeot expert
    no comunication with diagnostic tool
    LOVE DK!
  8. #66
    soxten's Avatar
    Mar 2013
    Open ecu and take photo to show us.
  9. The Following User Says Thank You to soxten For This Useful Post:
    gomarota (12th February, 2015)
  10. #67
    Any news on G201 pressure sensor? where to buy how to fix this ?
  11. The Following User Says Thank You to Speedofix For This Useful Post:
    soxten (3rd March, 2015)
  12. #68
    soxten's Avatar
    Mar 2013
    Any one as having info about Brake Pressure Sensor (G201)?
    where to buy new sensors?
    Is it only BOSCH OEM as having this part "new"?
    I still think that this problem is "dirt" from brakefluide as making the sensor broken.
    Even with ultrasonic cleaning you don`t get it inside the "channel" and upp to the bottom of the sensor.
    If someone has a way to connect this sensor to test it then I could make this test here on my bench.
    I have 1 broken and 1 working ABS unit here now.
  13. #69
    UK
    Hi all
    Does anyone know of a common fix for Vauxhall Astra H 2007 pls? No comms with abs module, dtc U2108. It has the continental Temic pcb. I can get photos if required.
    if this post was usefull
    please press
    the thanks button
  14. #70
    Lithuania
    Post photos, i think on this ones one of driver is dead
  15. #71
    UK
    OK, I will post pics in the morning. Thanks
  16. The Following User Says Thank You to looly For This Useful Post:
    Asassini (14th January, 2018)
  17. #72
    UK
    Quote Originally Posted by looly View Post
    Here are some pics of astra h abs module. Thanks
    please press
    the thanks button
  18. The Following 2 Users Say Thank You to looly For This Useful Post:
    mexanico1971 (14th September, 2016)
  19. #73
    Lithuania
    Chech all smd fuses ant power supplays on table
  20. The Following User Says Thank You to lagas For This Useful Post:
    looly (18th March, 2015)
  21. #74
    i_shot_the_sheriff's Avatar
    Nov 2008
    Fixed one of these ASTRA H abs modules by accident once,,,, it needed a simple reflow with hot air! Problem was ,, no comms with diagnostic at all!
    Not too much trouble to try that mate,,,,
  22. The Following 3 Users Say Thank You to i_shot_the_sheriff For This Useful Post:
    looly (18th March, 2015), mexanico1971 (21st October, 2016), Stelaras (24th November, 2017)
  23. #75
    UK
    Quote Originally Posted by i_shot_the_sheriff View Post
    Thats the exact fault that I've got. I'll take a look at fuses and also do a reflow. Thanks
    edit: is it possible to test with diag on bench (to see if comms is available)? If yes, does anyone have pinout pls?
    please press
    the thanks button
  24. The Following User Says Thank You to looly For This Useful Post:
