Microscope and time...
Anyone has news on pressure sender seller ?
What about the connection od the sensor ? It looks to me to have a digital output unfortunatelly. Can you confirm this please ? Pics attached fot you.
Peace and THX
lush29 (22nd January, 2016), mexanico1971 (14th September, 2016), soxten (22nd January, 2016)
I cant find this pressure sensor
But, black pcb is old one and green pcb is new one.
The green sensor I think is of bettee quality
i think m8 be wrong thinking.
a Lot of companys which Repair the Units dont change it.
i think they have the old soft from Elsa to fix the Problem. VW Do a shop linke a ....
they prog a value and Shut Up the Sensor in the soft. This Sensor You Need only for comfort in ESP. A Long Time this soft was in Elsa but After ( Garanty ) Time it was not there.
i will Look for a car with Strage Value in the soft.
No, you buy a new alu.block inc the sensor and change.
No change in soft in abs controll unit.
I see that some workshop rebuild the sensor and place it outside abs unit by wire.
I say that black pcb on pressure sensor is bad one and if to send it for repair/change you get a green pcb sensor.
The green sensor is build in a diffrent way compare to the black pcb sensor
JFR-Tuning (25th January, 2016)
Change alu block!
We cant find pressure sensor as new...
PierreTheron (9th February, 2016)
Does somebody have solution for bmw e46 ate abs module 10.0960 - 0805.3 with error 5D5F?
replace The combination drive IC such as 0990 etc by openning the plastic box
Sent from my SM-N900P using Tapatalk
bawareca (14th January, 2017), lush29 (6th March, 2016), Nikola1309 (7th March, 2016), soxten (7th March, 2016)
Do you mean 990-9377 1.D? On that IC I have mask 1A7JFT and cant find ic with that mask.Can i put with another mask?
Hello
YOu only need 0990-9377.1D, that is Correct part, no need to consider mask. I it Power driver and CAN communication Combination IC. Not Programmed IC. Buy it and replace! then using OSciloscop to Mearsure CAN signal, if avaliable, mean that Your ABS computer work well!
Do not need program or do anything else as Program. Just try to do AIR blessing!
Nikola1309 (10th March, 2016), PierreTheron (11th March, 2016)
Hello, I need help with this one. I soldered all points already but still it won't work.
I noticed that with the ABS still plugged to the car if I forced the PC board with a screw driver it would work for a few seconds.
Could someone give me a hint please?
BusCan (20th March, 2018)
like etpvn said problem is probably driver 990 etc,it is glued to some aluminium part that is on the board. i have some old unit and it is big problem to desolder driver. i sugest you until you get new driver dont remove old one.
