Page 6 of 21 FirstFirst 123456789101116 ... LastLast
Results 76 to 90 of 303
  1. #76
    Lithuania
    Yes you can do it on bench. Need have a look to wiring diagram. Corner ones in one side and other have positive and negative, and 18 or 32 ignition. Cant remember. Try to check tumorrow
  2. #77
    UK
    Quote Originally Posted by lagas View Post
    Ok that would be very much appreciated pls mate. Cheers!
    if this post was usefull
    please press
    the thanks button
  3. #78
    Lithuania
    Default How to repair ABS system and units thread (repair,help,questions)
    Ok the it is:
    26,13 pin's is Ground
    1, 14, 24 pin's is positive
    21 is CAN-Low
    23 is CAN-h
    First try power and measure can pins. Sould be ~2.33v or youse scope.
  4. The Following User Says Thank You to lagas For This Useful Post:
    looly (19th March, 2015)
  5. #79
    soxten's Avatar
    Mar 2013
    We are bright and clever people here on DK, but still we have problem to solve G201-brake pressure sensor fault....
    Ford/Volvo/Mazda use the same alu.block as call`d "2050"
    Here as a selling advertice http://www.ebay.co.uk/itm/FORD-MAZDA...-/400291561666
    BBA Reman fix this sensor problem and sell on ebay.
    "BBA-reman has been successfully repairing a huge range of ABS for many years and our happy to announce we are now offering exchange ATE MK60 valve blocks for pressure sensor repairs via eBay.Common faults include but are not limited to:
    • Traction control light on (ESP)
    • ABS light on
    • Pressure sensor fault codes (e.g. 5E20 / G201) .
    This listing is for an exchange modulator block 2050 only. You will have to use your motor and ECU.
    The warranty will only apply to the modulator block supplied.
    This block actually fits a wide range of units, please check the 4 digit number on your modulator unit and make sure it is 2050. If it isn't please check out our other listings or contact us with the details of the 4 digits from the unit you requirer.
    Most new ABS units requirer additional costs by needing programming. Since you are not changing the ECU, you will not need to recode it to the vehicle.
    This unit is always in stock available for same working day dispatch if your order is received by 1600 GMT with cleared payment.
    This item is sold as a Exchange replacement. So to make life a little easier for you included in the listing cost is return carriage enabling you to return your old unit trouble free."
    Do any here on DK have a clue how to fix this sensor problem?
  6. #80
    DK Veteran thomas76's Avatar
    Oct 2010
    The problem with sensor on MK60 is in sensor, wires alu connections break
    Just one solution : Remplacement sensor
    But i can not find seller for this
    Electronic Automobile
    If post usefull press
    "THANKS"
  7. The Following 12 Users Say Thank You to thomas76 For This Useful Post:
    armpower (11th May, 2015), darka7 (14th February, 2023), delio78 (5th December, 2019), digitaltuner (29th October, 2015), Hayssam1 (16th February, 2016), mexanico1971 (15th June, 2015), mtnt (1st April, 2015), narkeleptk (5th July, 2020), soxten (24th March, 2015), Speedofix (21st April, 2015), Stelaras (24th November, 2017), vasa (6th March, 2018)
  8. #81
    soxten's Avatar
    Mar 2013
    Any news on this Pressure sensor?
    We must find a seller of this sensors!!!
  9. #82
    Aug 2012
    Maybe the brake light signal will help
  10. #83
    soxten's Avatar
    Mar 2013
    ? Rewired?
  11. #84
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Anyone had any luck repairing Sprinter ABS with error C1401-007?
    I have checked all wires and replaced 3 MOSFET's under alu housing.
    Still same error.
  12. #85
    soxten's Avatar
    Mar 2013
    Pictures of abs unit Simaservis1108?
  13. #86
    Jan 2011
    Sent from my GT-I9505 using Tapatalk
  14. #87
    Jun 2013
    valencia,spain
    I just read all this excellent report and I find no solution to my problem, I have ATE BMW reference module ABS DTC 100960-08053 5DF5 and C1DF5 ....
    Repair any possible partner knows ?? Thanks
  15. #88
    Dec 2011
    Hi to all.
    I have problem with Peugeot 307.ABS light is on.Dash and motor ECU can't see speed sensor(speedo and mileage don't work,car don't have speed sensor, info for speed is from ABS) and ABS module.In BSI no errors.I can connect with ABS module and it has error "ABS module faulty". I open ABS module and there no broken wires(check with tweezers and microscope). ABS module is BOSCH 5.3(0273004562). I think its common problem for Peugeot.
    Did someone have decision for the problem?
  16. #89
    cubica1's Avatar
    Feb 2012
    Serbia
    a little contribution from my self for all members. Audi A6 2005y, ABS unit repairing.
    rgds,
    cuby
  17. The Following 7 Users Say Thank You to cubica1 For This Useful Post:
    diga1 (2nd May, 2016), hrmotorsport (11th June, 2021), lush29 (1st February, 2016), mexanico1971 (14th September, 2016), morfej (9th October, 2022), Pawelpl (25th January, 2021), PierreTheron (9th February, 2016)
  18. #90
    Oct 2015
    gaborone botswana
    great thnx mate
