Results 1 to 4 of 4
Thread: skoda fabia
    Jan 2025
    Default skoda fabia
    Hi can anyone help me with long coding for abs 8.2 6R0 907 379 S
    Instrument cluster was changed and mechanic never saved long coding,
    Skoda Fabia 1.2
    vin on vcds scan is : TMBFA25J4B3011220
    and vin of car is :TMBFA25J3B3170407
    1 RH drive
    2 electro mechanical steering
    3 no tpms or esp
    4 front discs 256mm and rear drums 200mm
    VCDSWindows Based VAG/VAS Emulator Running on Windows 11 x64VCDS Version: Release 23.11.0 Data version: 20231027 DS351.0www.Ross-Tech.comDealer/Shop Name:Workshop Code: 000 00000 000000Self-Diagnosis LogWednesday,22,January,2025,17:19:48:00009VIN: TMBFA25J4B3011220 License Plate: 11RNFERMileage: 157740km-98015mi Repair Order:Chassis Type: 5J-SK25 (6N0)Scan: 01 03 09 15 17 19 25 44 56VIN: TMBFA25J4B3011220 Mileage: 157740km-98015miles01-Engine -- Status: OK 000003-ABS Brakes -- Status: Malfunction 001009-Cent. Elect. -- Status: OK 000015-Airbags -- Status: OK 000017-Instruments -- Status: OK 000019-CAN Gateway -- Status: OK 000025-Immobilizer -- Status: OK 000044-Steering Assist -- Status: OK 000056-Radio -- Status: OK 0000------------------------------------------------------------------------------- Address 01: Engine (CHF) Labels: Redir Fail! Part No SW: 03D 906 023 M HW: 03D 906 023 M Component: SIMOS91 1.2l 2V 1718 Revision: --H05--- Serial number: Coding: 0000031 Shop #: WSC 33361 790 00007 VCID: 285F4DA798F312D1AB-515A VINID: 91D49644215A1120C004108200E08AE62FNo fault code found.Readiness: N/A-------------------------------------------------------------------------------VCDSSelf-Diagnosis LogWednesday,22,January,2025,17:19:48:00009Page 2VIN: TMBFA25J4B3011220 License Plate: 11RNFERAddress 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb Part No SW: 6R0 907 379 S HW: 6R0 907 379 AB Component: ABS8.2 front H03 0001 Revision: -------- Coding: 000000000000000000000000000000000000 Shop #: WSC 13765 790 00050 VCID: 4E93DB3F1DD72CE101-801A1 Fault Found:01042 - Control Module; Not Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 12 Reset counter: 176 Mileage: 157722 km Time Indication: 0 Date: 2019.06.15 Time: 22:32:33 Freeze Frame: Hex Value: 0x0005 Hex Value: 0x0000 Hex Value: 0x3213 Hex Value: 0x149D Hex Value: 0x00FF Hex Value: 0x007F Hex Value: 0x7F00 Hex Value: 0x0000-------------------------------------------------------------------------------VCDSSelf-Diagnosis LogWednesday,22,January,2025,17:19:48:00009Page 3VIN: TMBFA25J4B3011220 License Plate: 11RNFERAddress 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb Part No SW: 6R7 937 086 H HW: 6R7 937 086 H Component: PQ25 BCM H12 0022 Revision: -3------ Serial number: 1002480501 Coding: 65980B3808010000002000003E0B08800040400F6000000000 00 Shop #: WSC 13765 790 00050 VCID: 489FED27FBB3F2D14B-801C Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB Component: J386__TSG_FT 002 3210 Serial number: -------------------- Coding: 030000 Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB Component: J387__TSG_BT 002 3210 Serial number: -------------------- Coding: 020000No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 6R0 959 655 K HW: 6R0 959 655 K Component: VW10AirbagT2C H09 0020 Revision: -------- Serial number: 003GX00FEZ1V Dataset Number: t00301685J0 0001 Coding: 003243 Shop #: WSC 13765 790 00050 ASAM Dataset: EV_AirbaVW10BPAVW250 A01001 ROD: EV_AirbaVW10BPAVW250.rod VCID: 4A9BD72FEDBF00C15D-801E Crash sensor for side airbag: driver side: Serial number: 3495RRB40650DD2AFOMS Front Passenger's Side Airbag Crash Sensor: Serial number: 3505RRB40650DD2A6H9YNo fault code found. -------------------------------------------------------------------------------VCDSSelf-Diagnosis LogWednesday,22,January,2025,17:19:48:00009Page 4VIN: TMBFA25J4B3011220 License Plate: 11RNFERAddress 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1 Part No SW: 5J0 920 840 E HW: 5J0 920 840 E Component: KOMBI H13 0206 Serial number: 00000000000000 Coding: 110A00 Shop #: WSC 13765 031 00007 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052 ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod VCID: 2B55B2AB420539C946-807ENo fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb Part No SW: 6N0 909 901 HW: 6R7 937 086 H Component: GW-K-CAN TP20 0022 Revision: -3------ Coding: 032300 Shop #: WSC 13765 790 00050 VCID: 70EF65C7A3A31A1133-8024No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H13 0206 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: 6ADB77AF8D7FE0C17D-803ENo fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 6Q0-423-156.clb Part No: 6R0 423 156 B Component: LenkhilfeTRW V277 Coding: 10140 Shop #: WSC 13765 VCID: 2F6DA6BBEA1D45E96A-807ANo fault code found. -------------------------------------------------------------------------------VCDSSelf-Diagnosis LogWednesday,22,January,2025,17:19:48:00009Page 5VIN: TMBFA25J4B3011220 License Plate: 11RNFERAddress 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb Part No SW: 5J0 035 161 C HW: 5J0 035 161 C Component: Radio-SWING 009 0034 Revision: -----09S Serial number: SKZ4Z2L1138599 Coding: 050002000006 Shop #: WSC 13765 790 00050 VCID: 224B5F8F3DCFF881F5-8076No fault code found.End-------------------------(Elapsed Time: 01:37)--------------------------
    rafal's Avatar
    Jul 2010
    UK - PL
    Post full scan from vcds
    need help
    now my goal is to buy xp-005
    who will help?
    Jan 2025
    Hi just posted complete scan
    Tefocm's Avatar
    Sep 2013
    Planet Earth...Take me to your leader.
    did you manage? I can assist.
    Buy every pirate China has to offer for cheap...and WIN!
    Buy everything the original manufacturer has to SHOW YOUR SUPPORT!
