Hi mates,
I need your help. I change ate renault abs to donor with similiar reference. Now abs works perfect but gets dtc C006A
Can anyone help how to delete it? Maybe any configuration by diag.
Thanks a lot
Hi mates,
Thanks a lot
McDowell (9th January, 2024)
I have two Renault abs, one in a megane 2 and another in scenic 2 with C10C3 fault, does anyone know how to resolve this fault?
VRCars (14th April, 2025)
did you solve the problem?
Hi mates, i need your help to repair ABS unit Mazda CX-9 0265956483
One of PCB components is missing after crash, i'm searching for good picture of board.
It seems to be a diode, but i'm not sure. Thanx!
No friend, I had to replace it. I have already rejected repairing ABS, in the ATE MK60 with VAG fault 01130, I have changed the 990-9413B, reballed the MCU, reflashed and they appear again the moment the vehicle starts running. I have used several methods to replace the 990 and in no way, in the end all the same result.
I have a faulty ATE MK100 from a Volvo XC70 2007.
Is it possible to transfer all needed data from this unit by transfer eeprom to another second hand unit?
Or it it possible to make second hand unit virgin in any way?
does anyone know what transistor can i use to replace this one in bmw e39 DSC?
because i tried with spot welding........And it was not a good idea :P :P
If i Helped you,use thanks and rep button to thank me back
Can someone help me with the coding of an abs module for seat ibiza 2013 ?
the coding it’s lost and I need to get the code for my vehicle
Hello ABS masters, I'm new to ABS computers, I normally work with Airbag modules and have much experience, but never try ABS modules before, one of my customers needs help to adapt a used module from another car to his, that was damaged in the accident.
Can you guys explain me how does the new module (used from another car, same year same model) get adapted to the car? do i need to replace a microchip, do I need to reset or write the information from original?.
sorry I'm new to ABS, please any help will be very appreciated.
Hello guys Ford kuga abs pump
Found motor control circuit error code then found the motor itself was damaged replace that pump vehicle worked for 3 weeks back with same errors I check the pump itself it's good any ideas
can someone help me? u3000 abs failure ford Ecosport 2013.
