Page 17 of 31 FirstFirst ... 7121314151617181920212227 ... LastLast
Results 241 to 255 of 491
Hybrid View
    Oct 2017
    Lotzen
    I have a problem with a Skoda Fabia 1,2 TSI CBZB 2010, after swapping the dash for a used one, the ABS has lost its coding.
    Can anyone help please.
    This is the car:
    1. ABS module Part No SW: 6R0 907 379 S HW: 6R0 907 379 AB Component: ABS8.2 front H03 0001
    2. Exact model of the car SKODA FABIA
    3. Year of the car 2010
    4. VIN TMB1NB5J1B3039510
    5. Left hand drive
    6. Engine type (gas) 1,2 TSI CBZB
    7. FWD
    8. Provide front brake disc diameter, if known: 288 mm
    9. Is there any start/stop ("eco"/"bluemotion"/etc) system installed in the car? NO
    10. Is there any kind of TPMS? NO
    11. Does the car have ASR/ESP off buttons? NO
    12. "Hill hold" function. Does the car have one? NO Do you want it to be activated? YES If it possible and easy to do
    Would be great if you could help.
    Regards Peter
    Jul 2016
    Vilnius
    Can you please look up the VIn number in your new dash and post it here?
    * MK100
    Oct 2017
    Lotzen
    New dash was from car RHD with maxidot and it was mounted for a moment to checking some funkctions. My friend turn ignition on and ABS has lost coding. Now there is the old dash (oryginal from this car) and it stay in this car.
    If you want VIN from the new dash I must replace it again and check.
    I probably can't do that today, but tomorrow it is possible.
    Thank's for help.
    Jul 2016
    Vilnius
    No need to swap the dashes again.
    Try this coding, assuming the original dash is in place:
    400100DB007000BB022A00E300D100000000
    * MK100
    Hello!
    I need help coding the ABS 8.2 for my car :
    Skoda Fabia 2010r
    1.2 TSI 63 kw CBZA
    LHD
    Start-Stop- no
    TMPS - no
    VIN. TMBEM25J9B3167689
    Pomp. 6R0907379S
    Thank you in advance
    Jul 2016
    Vilnius
    try this for the Fabia:
    400100DB007300B9022B00EA00DA00000000
    * MK100
  7. The Following User Says Thank You to hid3 For This Useful Post:
    orlik1 (21st October, 2017)
    work perfect
    thank you
    Oct 2017
    Lotzen
    Hello hid3!
    Thank you very much for your help, encoding accepted . I checked it yesterday (as soon as I can)
    Thank you! Regards!
  10. #9
    Oct 2012
    Hello
    need help long coding
    Vw polo
    ESP 8.2i front H04 0002
    6R0 907 379R
    WVWZZZ6RZAY194968
    1.2 Petrol LHD TPMS
  11. #10
    Nov 2017
    Hello
    I need long code for my 2010 6R Polo Trendline
    I've tried several code without success...
    6R0 907 379 AJ
    1.6 diesel CAYB
    LHD
    FWD, manuel transmission
    256mm/232mm brake
    ASR/ESP off button
    No Start/stop
    No TPMS
    Hill-hold activated
    WVWZZZ6RZBY124617
    Can someone help me?
  12. #11
    ypiter's Avatar
    Jan 2012
    RUSSIA
    Quote Originally Posted by tom a4 View Post
    Hello
    Vw polo
    6R0 907 379R
    WVWZZZ6RZAY194968
    1.2 Petrol LHD TPMS
    Try
    210224C2007600B6842E24E800D900400000
  13. #12
    Nov 2017
    After lot of searching and analysing, i've found a code who worked!
    210228E3416F00B6842B14E382D800421000
    But the code is for automatic transmission, my polo got manual transmission...
    Got a default "Code not valid" and not allowed to set ESP and steering wheel
    Here the code I need but not allowed
    210228E3216F00B6842B14E384D800421000
    Where is the problem and how can i do to solve it?
  14. #13
    Nov 2017
    Still have a problem with my ABS code.
    The only code accepted is for automatic but my gearbox is manual.
    And can't abble to reactivate the hill-hold.
    The problem appear before testing of dashboard coming from Polo with DSG.
    Does anyone know where is the problem and how can I solve it?
    Quote Originally Posted by JRD View Post
    Hello
    6R0 907 379 AJ
    1.6 diesel CAYB
    LHD
    256mm/232mm brake
    ASR/ESP off button
    No Start/stop
    No TPMS
    Hill-hold activated
    WVWZZZ6RZBY124617
  15. #14
    Nov 2017
    Quote Originally Posted by ypiter View Post
    Try
    I think this code won't work because no gearbox type assigned nd model error
    Better trying 210224E3217600B684E224E884D900400000 for manual
    or 210224E3417600B684E224E882D900400000 for automatic
  16. #15
    Nov 2017
    Default Help with lost Fabia 2012 abs code
    Hi lost abs code on Fabia 2012 6r0907379s
