Page 18 of 33 FirstFirst ... 8131415161718192021222328 ... LastLast
Results 256 to 270 of 491
  1. #256
    DK Veteran thomas76's Avatar
    Oct 2010
    Quote Originally Posted by hid3 View Post
    Too bad
    Do you have VCDS? Is there any chance you could do full car's scan with it?
    VCDS and AUTEL AVDI, you want i scan full car ?
    Electronic Automobile
    If post usefull press
    "THANKS"
  2. #257
    Jul 2016
    Vilnius
    Yes, please do full AUtoscan of the car. Very preferably with VCDS.
    * MK100
  3. #258
    Oct 2010
    Joigned full SCAN with VCDS
    Thanks,
    "THANKS"
  4. #259
    Jul 2016
    Vilnius
    Let's try this one:
    210248E3416F02B8842D12E282D340411700
    Let me know if it accepts. If not, then note what's the rejection code/message is.
    * MK100
  5. #260
    Oct 2010
    Cool
    Let's try this one:
    It's OK very GOOD
    You are the BEST !!!
    Very thanks !
    "THANKS"
  6. #261
    Jul 2016
    Vilnius
    Glad it worked! It's very difficult to code these modules for me.
    * MK100
  7. #262
    DK Veteran rsibiza's Avatar
    Hey Ho. Just wanting to ask if someone could check something for me.
    Pls find autoscan attached, had read the coding before, but new ABS wont accept it and give error 22
    The read out Longcoding is: 100248DB017200BB082A12E580D300020000 , but ecu wont actually accept it
    any ideas?
    Cant attach the scan, so ill post it :
    F~~~~~g,19,Januar,2018,18:56:58:65394
    VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 8.1 x64
    VCDS Version: DRV 17.8.0.1 HEX-V2 CB: 0.4409.4
    Datenstand: 20170817 DS276.4
    www.Ross-Tech.de
    Fahrzeug-Ident.-Nr.: VSSZZZ6JZ9R059532 KFZ-Kennzeichen:
    Kilometerstand: 214950km Reparaturauftrag:
    Fahrzeugtyp: 6J-SE25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
    Fahrzeug-Ident.-Nr.: VSSZZZ6JZ9R059532 Kilometerstand: 214950km
    01-Motorelektronik -- Status: Fehler 0010
    03-Bremsenelektronik -- Status: Fehler 1010
    04-Lenkwinkelsensor -- Status: i.O. 0000
    08-Klima-/Heizungsel. -- Status: Fehler 0010
    09-Zentralelektrik -- Status: Fehler 0010
    15-Airbag -- Status: Fehler 0010
    17-Schalttafeleinsatz -- Status: Fehler 0010
    19-Diagnoseinterface -- Status: Fehler 0010
    25-Wegfahrsperre -- Status: i.O. 0000
    44-Lenkhilfe -- Status: i.O. 0000
    4B-Multifunktionsstg. -- Status: Fehler 0010
    56-Radio -- Status: Fehler 0010
    Adresse 01: Motorelektronik Labeldatei: DRV\03G-906-021-BLS.clb
    Teilenummer SW: 03G 906 013 K HW: 03G 906 013 K
    Bauteil: R4 1,9L EDC 0000SG 2940
    Revision: --H04--- Seriennummer:
    Codierung: 0053071
    Betriebsnr.: WSC 06402 785 00200
    VCID: 280808665EFCEC6733A-807C
    8 Fehlercodes gefunden:
    049441 - Steuergerät für ABS Bremse
    U0121 - 000 - keine Kommunikation - Sporadisch - Warnleuchte EIN
    Umgebungsbedingungen:
    Fehlerstatus: 10100000
    Fehlerpriorität: 2
    Fehlerhäufigkeit: 1
    Verlernzähler: 255
    Kilometerstand: 214959 km
    Zeitangabe: 0
    Drehzahl: 0 /min
    Geschwindigkeit: 4.0 km/h
    Last: 0.0 %
    Spannung: 12.01 V
    Binärwert: 00000100
    Drehmoment: 0.0 Nm
    Binärwert: 10000000
    001350 - Geber 1 für Abgastemperatur (G235)
    P0546 - 000 - Kurzschluss nach Plus - Sporadisch
    Fehlerstatus: 00100000
    Fehlerpriorität: 2
    Fehlerhäufigkeit: 1
    Verlernzähler: 255
    Zeitangabe: 0
    Drehzahl: 0 /min
    Last: 0.0 %
    Spannung: 12.01 V
    Temperatur: 14.4°C
    Temperatur: 930.0°C
    Druck: 948.6 mbar
    005213 - Geber 3 für Abgastemperatur
    P145D - 000 - Kurzschluss nach Plus - Sporadisch
    Fehlerpriorität: 2
    Fehlerhäufigkeit: 1
    Verlernzähler: 255
    Zeitangabe: 0
    Drehzahl: 0 /min
    Spannung: 12.01 V
    Temperatur: 14.4°C
    Temperatur: 930.0°C
    Temperatur: 930.0°C
    006488 - Geber 2 für Abgastemperatur Bank 1 (G448)
    P1958 - 000 - Kurzschluss nach Plus - Sporadisch
    Fehlerpriorität: 2
    Fehlerhäufigkeit: 1
    Verlernzähler: 255
    Zeitangabe: 0
    Drehzahl: 0 /min
    Spannung: 12.01 V
    Temperatur: 14.4°C
    Temperatur: 930.0°C
    Temperatur: 930.0°C
    000579 - Magnetventil für Ladedruckbegrenzung (N75)
    P0243 - 000 - Unterbr. / Kurzschluss nach Masse - Sporadisch
    Fehlerpriorität: 2
    Fehlerhäufigkeit: 1
    Verlernzähler: 255
    Zeitangabe: 0
    Drehzahl: 0 /min
    Last: 0.0 %
    Spannung: 12.01 V
    Binärwert: 00000100
    Druck: 1040.4 mbar
    Druck: 948.6 mbar
    000258 - Luftmassenmesser (G70)
    P0102 - 000 - Signal zu klein - Sporadisch - Warnleuchte EIN
    Fehlerpriorität: 2
    Fehlerhäufigkeit: 1
    Verlernzähler: 255
    Zeitangabe: 0
    Drehzahl: 0 /min
    Last: 0.0 %
    Tastverhältnis: 100.3 %
    Binärwert: 00000100
    Luftmasse/Hub: 680.0 mg/H
    Luftmasse/Hub: 0.0 mg/H
    004374 - Bank 1 Sonde 1; Heizstromkreis
    P1116 - 000 - Unterbrechung - Sporadisch
    Fehlerpriorität: 2
    Fehlerhäufigkeit: 1
    Verlernzähler: 255
    Zeitangabe: 0
    Drehzahl: 0 /min
    Last: 0.0 %
    (keine Einheit): 1.00
    (keine Einheit): 0.0
    Binärwert: 11001000
    012294 - Relais für große Heizleistung (J360)
    P3006 - 000 - Unterbrechung/Kurzschluss nach Masse
    Fehlerstatus: 01100000
    Fehlerpriorität: 2
    Fehlerhäufigkeit: 5
    Verlernzähler: 255
    Zeitangabe: 0
    Drehzahl: 0 /min
    Last: 0.0 %
    Spannung: 12.01 V
    Binärwert: 00000100
    Last: 24.3 %
    Binärwert: 00000001
    Readiness: 1 7 0 0 1
    Adresse 03: Bremsenelektronik (J104) Labeldatei:. DRV\6R0-907-37x-ABS82.clb
    Teilenummer SW: 6R0 907 379 AD HW: 6R0 907 379 AB
    Bauteil: ABS8.2 front H03 0001
    Revision: --------
    Codierung: 000000000000000000000000000000000000
    Betriebsnr.: WSC 00000 000 00000
    VCID: 005870C69A4CF4275BA-8054
    6 Fehlercodes gefunden:
    01042 - Steuergerät nicht codiert
    000 - -
    Fehlerpriorität: 0
    Fehlerhäufigkeit: 12
    Verlernzähler: 0
    Kilometerstand: 214958 km
    Zeitangabe: 0
    Datum: 2012.06.09
    Zeit: 17:48:51
    Hex Wert: 0x0005
    Hex Wert: 0x0000
    Hex Wert: 0x1113
    Hex Wert: 0x1487
    Hex Wert: 0x00FF
    Hex Wert: 0x007F
    Hex Wert: 0x7F00
    Hex Wert: 0x0000
    01314 - Motorsteuergerät
    004 - kein Signal/Kommunikation - Sporadisch
    Fehlerstatus: 00100100
    Fehlerpriorität: 0
    Verlernzähler: 40
    Kilometerstand: 214957 km
    Zeitangabe: 0
    Datum: 2012.06.09
    Zeit: 13:28:18
    Hex Wert: 0x0005
    Hex Wert: 0x0000
    Hex Wert: 0x11A0
    Hex Wert: 0x1388
    Hex Wert: 0x00FF
    Hex Wert: 0x007F
    Hex Wert: 0x7F00
    Hex Wert: 0x0000
    00287 - Drehzahlfühler hinten rechts (G44)
    012 - elektrischer Fehler im Stromkreis - Sporadisch
    Fehlerstatus: 00101100
    Fehlerpriorität: 0
    Fehlerhäufigkeit: 1
    Verlernzähler: 40
    Zeitangabe: 0
    Datum: 2012.06.11
    Zeit: 00:17:59
    Hex Wert: 0x0005
    Hex Wert: 0x0000
    Hex Wert: 0x10B1
    Hex Wert: 0x09A0
    Hex Wert: 0x00FF
    Hex Wert: 0x007F
    Hex Wert: 0x7F00
    Hex Wert: 0x0000
    03306 - Codierung ungültig
    008 - unplausibles Signal - Sporadisch
    Fehlerstatus: 00101000
    Fehlerpriorität: 0
    Fehlerhäufigkeit: 13
    Verlernzähler: 40
    Zeitangabe: 0
    Datum: 2012.06.11
    Zeit: 13:42:36
    Hex Wert: 0x0001
    Hex Wert: 0x0000
    Hex Wert: 0x1003
    Hex Wert: 0x1699
    Hex Wert: 0x00FF
    Hex Wert: 0x007F
    Hex Wert: 0x7F00
    Hex Wert: 0x0000
    000 - - - Sporadisch
    Fehlerpriorität: 0
    Fehlerhäufigkeit: 4
    Verlernzähler: 40
    Zeitangabe: 0
    Datum: 2012.06.11
    Zeit: 13:57:12
    Hex Wert: 0x0001
    Hex Wert: 0x0000
    Hex Wert: 0x1027
    Hex Wert: 0x1499
    Hex Wert: 0x00FF
    Hex Wert: 0x007F
    Hex Wert: 0x7F00
    Hex Wert: 0x0000
    00285 - Drehzahlfühler vorn rechts (G45)
    Fehlerstatus: 01101100
    Fehlerpriorität: 0
    Fehlerhäufigkeit: 3
    Verlernzähler: 0
    Zeitangabe: 0
    Datum: 2012.06.11
    Zeit: 18:31:06
    Hex Wert: 0x0005
    Hex Wert: 0x0000
    Hex Wert: 0x10B1
    Hex Wert: 0x0791
    Hex Wert: 0x00FF
    Hex Wert: 0x007F
    Hex Wert: 0x7F00
    Hex Wert: 0x0000
    Adresse 08: Klima-/Heizungsel. (J255) Labeldatei: 6R0-907-044.clb
    Teilenummer SW: 6J0 820 043 HW: 6J0 820 043
    Bauteil: Climatronic H07 0203
    Revision: S0000000
    VCID: 619E554271465D2F344-8034
    9 Fehlercodes gefunden:
    01316 - Bremsensteuergerät
    013 - bitte Fehlerspeicher auslesen - Sporadisch
    Fehlerstatus: 00101101
    Fehlerpriorität: 6
    Fehlerhäufigkeit: 2
    Verlernzähler: 40
    Zeitangabe: 0
    Datum: 2012.06.06
    Zeit: 07:59:05
    Fehlerpriorität: 6
    Fehlerhäufigkeit: 20
    Verlernzähler: 40
    Zeitangabe: 0
    Datum: 2012.06.06
    Zeit: 07:59:10
    00447 - Funktionseinschränkung durch Überspannung
    001 - oberer Grenzwert überschritten - Sporadisch
    Fehlerstatus: 00100001
    Fehlerpriorität: 3
    Fehlerhäufigkeit: 2
    Verlernzähler: 40
    Zeitangabe: 0
    Datum: 2012.06.09
    Zeit: 10:16:11
    01317 - Steuergerät im Schalttafeleinsatz (J285)
    Fehlerpriorität: 6
    Fehlerhäufigkeit: 1
    Verlernzähler: 40
    Zeitangabe: 0
    Datum: 2012.06.09
    Zeit: 13:06:18
    Fehlerpriorität: 6
    Fehlerhäufigkeit: 1
    Verlernzähler: 40
    Zeitangabe: 0
    Datum: 2012.06.09
    Zeit: 13:33:26
    Fehlerpriorität: 6
    Fehlerhäufigkeit: 1
    Verlernzähler: 40
    Zeitangabe: 0
    Datum: 2012.06.09
    Zeit: 18:04:41
    00446 - Funktionseinschränkung durch Unterspannung
    002 - unterer Grenzwert unterschritten - Sporadisch
    Fehlerstatus: 00100010
    Fehlerpriorität: 3
    Fehlerhäufigkeit: 1
    Verlernzähler: 40
    Zeitangabe: 0
    Datum: 2012.06.10
    Zeit: 00:07:38
    00457 - Steuergerät für Bordnetz (J519)
    Fehlerpriorität: 6
    Fehlerhäufigkeit: 1
    Verlernzähler: 40
    Zeitangabe: 0
    Datum: 2012.06.10
    Zeit: 00:14:09
    01299 - Diagnose-Interface für Datenbus (J533)
    Fehlerpriorität: 6
    Fehlerhäufigkeit: 1
    Verlernzähler: 40
    Zeitangabe: 0
    Datum: 2012.06.10
    Zeit: 00:14:09
    Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\6R0-937-08x-09.clb
    Teilenummer SW: 6R0 937 087 HW: 6R0 937 087
    Bauteil: PQ25 BCM H06 0012
    Revision: BF006001 Seriennummer: 9425A204080769
    Codierung: 7C8829A88861010000200000760B1CC80000400F608C000020 00
    Betriebsnr.: WSC 64564 324 38760
    VCID: 7AAC022EFCD0AEF715E-802E
    Subsystem 1 - Teilenummer SW: 6R0 959 801 HW: 6R0 959 801 Labeldatei: 6R0-959-801.CLB
    Bauteil: J386__TSG_FT 001 0229
    Seriennummer: --------------------
    Codierung: 020000
    Subsystem 2 - Teilenummer SW: 6R0 959 802 B HW: 6R0 959 802 B Labeldatei: 6R0-959-802.CLB
    Bauteil: J387__TSG_BT 001 0233
    Codierung: 020000
    1 Fehler gefunden:
    00077 - Endschalter für Scheibenwischer (F229)
    Fehlerpriorität: 3
    Fehlerhäufigkeit: 2
    Verlernzähler: 229
    Zeitangabe: 0
    Datum: 2012.06.09
    Zeit: 00:22:12
    Adresse 15: Airbag (J234) Labeldatei:| DRV\5K0-959-655.clb
    Teilenummer SW: 6R0 959 655 K HW: 6R0 959 655 K
    Bauteil: VW10AirbagB11 H09 0020
    Revision: -------- Seriennummer: 003GX005Y1JP
    Codierung: 003131
    Betriebsnr.: WSC 07950 995 999999
    ASAM Datensatz: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250_VW31.rod
    VCID: 4ACC92EEEC30FE77C5E-801E
    Crashsensor für Seitenairbag Fahrerseite:
    Seriennummer: 3496GRB402LDIMQ2TCEO
    Crashsensor für Seitenairbag Beifahrerseite:
    Seriennummer: 3506GRB402NDIMQ2RSCU
    3 Fehlercodes gefunden:
    12854016 - Steuergerät für Schalttafeleinsatz
    U0423 00 [008] - unplausibles Signal
    Sporadisch - bestätigt - geprüft seit letzter Löschung
    Fehlerstatus: 00000001
    Fehlerpriorität: 6
    Fehlerhäufigkeit: 1
    Verlernzähler: 40
    Datum: 2018.01.19
    Zeit: 00:07:05
    12656896 - Steuergerät für ABS Bremse
    U0121 00 [008] - keine Kommunikation
    Fehlerpriorität: 6
    Fehlerhäufigkeit: 1
    Verlernzähler: 40
    Datum: 2018.01.17
    Zeit: 00:22:27
    12666368 - Diagnoseinterface für Datenbus
    U0146 00 [008] - keine Kommunikation
    Fehlerpriorität: 6
    Fehlerhäufigkeit: 1
    Verlernzähler: 40
    Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5K0-920-xxx-17.clb
    Teilenummer SW: 6J0 920 800 L HW: 6J0 920 800 L
    Bauteil: KOMBI 017 0018
    Seriennummer: 00000000000000
    Codierung: 110A00
    ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A04020
    ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
    VCID: 2F3AE37A7792BB5FF20-807A
    1 Fehler gefunden:
    12656896 - Funktionseinschränkung wegen fehlender Botschaft
    U1111 00 [008] - -
    Fehlerpriorität: 6
    Fehlerhäufigkeit: 2
    Verlernzähler: 40
    Kilometerstand: 0 km
    Datum: 2018.01.19
    Zeit: 00:00:00
    Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\6N0-909-901-6R.clb
    Teilenummer SW: 6N0 909 901 HW: 6R0 937 087
    Bauteil: GW-K-CAN TP20 0012
    Codierung: 422000
    VCID: 70B82006AAACE4A7ABA-8024
    1 Fehler gefunden:
    Fehlerpriorität: 2
    Fehlerhäufigkeit: 1
    Verlernzähler: 229
    Zeitangabe: 0
    Datum: 2012.06.09
    Zeit: 00:21:03
    Adresse 4B: Multifunktionsstg. Labeldatei: DRV\6J0-959-441.clb
    Teilenummer: 6J0 959 441
    Bauteil: MF-Modul 0007 0001
    Codierung: 0000001
    Betriebsnr.: WSC 77005 000 00000
    VCID: 70B82006A6ACE4A7ABA-8024
    2 Fehlercodes gefunden:
    00849 - S-Kontakt am Zündanlassschalter (D)
    Ende--(Dauer: 01:05, Batt.-Spannung Start/Ende: 12.0V/12.0V. VIgn 11.9V)---
  8. #263
    Jul 2016
    Vilnius
    That 22 "conditions not correct" code sucks
    I don't know why it occurs and what's the workaround for it.
    Why the coding was lost? Module replaced? Or any other repairs?
    * MK100
  9. #264
    Hi, thanks for your answer. ABS module was replaced, as pump was defektive
    Module nr has changed from 6R0 907 379 to 6R0 907 375 AD
  10. #265
    Jul 2016
    Vilnius
    Can you provide the full info of the new module?
    A snip of 03 ABS Brakes scan would be sufficient.
    * MK100
  11. #266
    Mar 2011
    EU
    someone can help with long coding esp8.2
    I tried with esp8.2 calculator but doesn't work
    VIN: WVWZZZ6RZAY262184 License Plate: POLO
    Mileage: 131630km-81791mi Repair Order:
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 03 08 09 10 15 17 19 25 2E 44 56
    VIN: WVWZZZ6RZAY262184 Mileage: 131630km-81791miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: Cannot be reached 1100
    44-Steering Assist -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine (J623-CAYA) Labels:. 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 E HW: 03L 906 023 D
    Component: R4 1.6l TDI H13 9979
    Revision: --H13--- Serial number:
    Coding: 00114014002400080000
    Shop #: WSC 124697 483 00190
    ASAM Dataset: EV_ECM16TDI02103L906023E 003017
    ROD: EV_ECM16TDI02103L906023AH_003.rod
    VCID: 285F15D55322D006E2-807C
    2 Faults Found:
    9862 - External Control Module
    P150F 00 [038] - Incorrectly Coded
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 131639 km
    Date: 2018.01.31
    Time: 18:32:07
    Engine speed: 781.00 /min
    Normed load value: 16.5 %
    Vehicle speed: 0 km/h
    Coolant temperature: 28 °C
    Intake air temperature: 9 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 14.231 V
    Unlearning counter according OBD: 40
    9859 - Sensor for Ambient Air Temperature (G17)
    P0073 00 [039] - Signal too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 131639 km
    Date: 2018.01.31
    Time: 18:32:08
    Engine speed: 780.50 /min
    Normed load value: 16.9 %
    Ambient air pressure: 990 mbar
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ABS82.clb
    Part No SW: 6R0 907 379 AE HW: 6R0 907 379 AC
    Component: ABS8.2 front H04 0001
    Revision: --------
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 02069 000 00000
    VCID: 010968719CD8C14E85-8054
    2 Faults Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 78
    Mileage: 131639 km
    Time Indication: 0
    Date: 2012.06.23
    Time: 18:27:52
    Freeze Frame:
    Hex Value: 0x0005
    Hex Value: 0x0000
    Hex Value: 0x3213
    Hex Value: 0x148E
    Hex Value: 0x00FF
    Hex Value: 0x007F
    Hex Value: 0x7F00
    Hex Value: 0x0000
    03306 - Coding Not Valid
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 118
    Mileage: 131634 km
    Time Indication: 0
    Date: 2012.06.20
    Time: 00:39:19
    Freeze Frame:
    Hex Value: 0x0001
    Hex Value: 0x0000
    Hex Value: 0x1227
    Hex Value: 0x1492
    Hex Value: 0x00FF
    Hex Value: 0x007F
    Hex Value: 0x7E00
    Hex Value: 0x0000
    Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
    Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
    Component: Climatic 24 0660
    Revision: 00 10 24
    VCID: 3561CCA19C90BDEE69-8060
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 78
    Mileage: 131639 km
    Time Indication: 0
    Date: 2012.06.23
    Time: 18:32:06
    Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
    Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
    Component: BCM PQ25 H+4 H46 0207
    Revision: BF046001 Serial number: 0147 100100979
    Coding: 3CB02BBF08A10000003800007D2B0CD00080410F6084000020 0000000000
    VCID: 3E73D38DA9A67EB6B8-806A
    Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 008 1611
    Serial number: KU0KU017041200013291
    Coding: 18BC30
    Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
    Component: J387__TSG_BT 008 1611
    Serial number: KU0KU015041200010014
    Coding: 18BC30
    Subsystem 3 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H05 0010
    Serial number: 0075902
    Coding: 020000
    Subsystem 4 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
    Component: J388__TSG_HL 008 1611
    Serial number: KU0KU020031200012162
    Coding: 18BC32
    Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
    Component: J389__TSG_HR 008 1611
    Serial number: KU0KU026031200015663
    Coding: 18BC32
    2 Faults Found:
    03428 - Activation of Left Adaptive Light
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 78
    Mileage: 131639 km
    Time Indication: 0
    Date: 2012.06.23
    Time: 18:32:07
    03429 - Activation of Right Adaptive Light
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 78
    Mileage: 131639 km
    Time Indication: 0
    Date: 2012.06.23
    Time: 18:32:07
    Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
    Part No SW: 6R0 919 475 HW: 6R0 919 475
    Component: PARKHILFE 4K H07 0008
    Revision: -------- Serial number: 71391009038258
    Coding: 100001
    ASAM Dataset: EV_VW250ParkiAssis2 S01006
    ROD: EV_VW250ParkiAssis2.rod
    VCID: 7BF51A99F234AB9EDF-802E
    No fault code found.
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
    Component: VW10Airbag00K H08 0020
    Revision: -------- Serial number: 003GX0011FUD
    Coding: 00304B
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250_VW25.rod
    VCID: 4A9B8F5DED6EC21614-801E
    Crash sensor for side airbag: driver side:
    Serial number: 357 RB4000000000004
    Crash sensor for side airbag: front passenger side:
    Serial number: 358 RB4000000000005
    Crash sensor for side airbag: rear: driver side:
    Serial number: 3515RRB404T6NG4A6P7+
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 3525RRB405N6NG4EA99V
    8 Faults Found:
    9443146 - Driver's Side Airbag Crash Sensor
    B1017 4A [137] - Incorrect component(s) installed
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 131639 km
    Date: 2018.01.31
    Time: 18:32:06
    9443091 - Driver's Side Airbag Crash Sensor
    B1017 13 [137] - Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 131639 km
    Date: 2018.01.31
    Time: 18:32:08
    9451082 - Crash sensor side airbag; passenger side
    B1036 4A [137] - Incorrect component(s) installed
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 131639 km
    Date: 2018.01.31
    Time: 18:32:06
    9451027 - Crash sensor side airbag; passenger side
    B1036 13 [137] - Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 131639 km
    Date: 2018.01.31
    Time: 18:32:08
    9437723 - Igniter for Passenger's Airbag
    B1002 1B [137] - Resistance Too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 131639 km
    Date: 2018.01.31
    Time: 18:32:09
    9438746 - Igniter for Seat Belt Tensioner; Driver's Side
    B1006 1A [137] - Resistance Too Low
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 131639 km
    Date: 2018.01.31
    Time: 18:32:09
    9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
    B1007 1B [137] - Resistance Too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 131639 km
    Date: 2018.01.31
    Time: 18:32:09
    10487296 - Control Module Does Not Match Vehicle
    B2006 00 [137] - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 131639 km
    Date: 2018.01.31
    Time: 18:32:06
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
    Part No SW: 6R0 920 861 D HW: 6R0 920 861 D
    Component: KOMBI H13 0024
    Serial number: 00000002304977
    Coding: 140A00
    ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01004
    ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
    VCID: 3663CBAD8996B6F660-8062
    1 Fault Found:
    9453330 - Outside temperature sensor
    B103F 1B [009] - Resistance Too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 78
    Mileage: 131639 km
    Date: 2018.01.31
    Time: 18:32:05
    Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R0 937 087 D
    Component: GW-K-CAN TP20 0207
    Coding: 002200
    VCID: 70EF3DB5A372D8C67A-8024
    1 Fault Found:
    02078 - Media Player Position 3 (R120)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 78
    Mileage: 131639 km
    Time Indication: 0
    Date: 2012.06.23
    Time: 18:32:12
    Address 25: Immobilizer (J285) Labels:. 5K0-920-xxx-25.clb
    Component: IMMO H13 X005
    Serial number:
    ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
    ROD: EV_ImmobUDSJCIPQ25.rod
  12. #267
    number7hd's Avatar
    Dec 2013
    Need long coding:
    SEAT LEON CUPRA
    VIN: VSSZZZ5FZGR176572
    __________________________________________________ ___________________________________
    Control Module Part Number: 5Q0 614 517 BK
    Component and/or Version: ESC H62 0736
    Software Coding: 00000000000000000000000000000000000000000000000000 000000000000
    Work Shop Code: WSC 33361
    VCID: 7BEBDCCFA3E5995A4AB2991-802E
    Advanced Identification/FAZIT
    Serial number: 62056000001715
    Identification: TT1-0CC
    Revision: 00000000
    Date: 23.07.16
    Manufacturer number: 0301
    Test stand number: 06B3
    Flash Status
    Programming Attempts(application): 0/0
    Flash Date: 00.01.01
    Misc.
    Hardware number: 5Q0 614 517 AH
    Workshop System Name: J104
    Equipment/PR Code: FFFFFFFFFFFFFFFF
    ASAM Dataset: EV_Brake1UDSContiMK100IPB
    ASAM Dataset Revision: 035019
    __________________________________________________ _______________________________________
    If my solution helped You - do not forget to THANKS !!!
  13. The Following User Says Thank You to number7hd For This Useful Post:
    azzou2 (4th February, 2018)
  14. #268
    Apr 2016
    Hello;
    I looking for long coding to ABS POLO 2012 1.4
    6R0 907 379 AD
    WVWZZZ6RZDY02176
    HELP ME PLZ.
  15. #269
    Jul 2016
    Vilnius
    1.4 Gas or Diesel?
    Left Hand drive or Right Hand drive?
    What are the module's SW and HW part numbers? I need both of them, not just one you provided.
    * MK100
  16. #270
    Apr 2016
    1.4 GAS Left hand drive
