Hi.
I need coding Seat Ibiza 6J 1.2TDI CFWA LHD
VSSZZZ6JZCR021159
ABS 6R0907379AD ABS8.2 Front
Hi.
VSSZZZ6JZCR021159
hello , can you help me with coding of this airbag
Freins ABS (J104) Labels:. 6R0-907-37x-ESP82.clb
SW: 6R0 907 379 BB HW: 6R0 907 379 AH
Piece: ESP8.2i front H07 0001
Révision: --------
Coding: 000000000000000000000000000000000000
No. Atelier: WSC 00046 000 00000
VCID: 7F0DB5FDEAFD7BB2AC-802A
VIN: WAUZZZ8X8CB044501
thank you in advance
hi ny one can help me to get ABS code for my polo vin WVWBC2A75CT010159 ABS8.2 front vag part number 6RF907379A ver H03 thanks
hi all
hello I Can please help me coding .
ESP 1K0 907 379 AJ
VW GOLF 6 2.0
WVWZZZ1KZ9W412615
THANSK
DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etcDo not forget to press the button thanks and reputation
# Algerian #
Hi there,
I need some help, I got stuck with abs on Skoda Fabia (vin:TMBES45J2C31011620; engine code:CAYA; LHD )
old abs module 6R0 907 379 S have some issue with the power to the pump, so I swap it with 6R0 907 379 AG, now I am not able to code it with the old code from the orginal modul ( long code: 400100DB006D00B3022B00E400D100000000 ) it gives an error 22 code rejected.
thanks in advance,
Hi !
Coding change to 0000000000 after instaling for a moment instruments from my friend car
off corse I did not autoscan before this :-(
RCD310 is safe and abs/esp, tpms is flasing. CAn anoyone help here ?
I tried
210224C2217200B2842924E584D800401200
210224C2217200B2842924E584D800400200
but it's not working "error 22"
Code:Saturday, 14, December, 2019.16: 36: 03: 00001 VCDS - VAG / VAS emulator working in Windows environment, running on Windows 7 x64 VCDS version: AKP 17.1.3.0 Data version: 20170621 DS267.7 www.vcds.pl VIN: WVWZZZ6RZCY250437 Registration number: Chassis type: 6R (6N0) Scanning: 01 03 04 08 09 15 17 19 25 44 56 VIN: WVWZZZ6RZCY250437 Mileage: 165670km 01-Engine - Status: OK 0000 03-ABS / brakes - Condition: Malfunction 0010 04-Steering angle - Status: OK 0000 08-Air conditioning - Status: OK 0000 09-Centr.zesp.elektr. - Condition: Fault 0010 15-Airbag - Status: OK 0000 17-Gauge Set - Status: OK 0000 19-CAN Gateway - Status: OK 0000 25-Immobilizer - Status: OK 0000 44-Steering wheel - Status: OK 0000 56-Radio - Status: OK 0000 -------------------------------------------------- ----------------------------- Address 01: Engine Label file: 03C-906-024-BXW.lbl Item designation SW: 03C 906 024 CN HW: 03C 906 024 BH Component: CGGB MM4HV 8994 Verification: --H09 --- Serial number: Coding: 0000071 Service code: WSC 00788 648 00255 VCID: 6CD6FC2C4C8BF62125-5072 No errors found. Standby codes: 0110 0001 -------------------------------------------------- ----------------------------- Address 03: ABS / Brakes (J104) Label file: 6R0-907-37x-ESP82.clb Item designation SW: 6R0 907 379 BC HW: 6R0 907 379 AF Component: ESP8.2i front H05 0002 Verification: -------- Coding: 000000000000000000000000000000000000 Service code: WSC 00788 648 00255 VCID: 000EB89C97030241E9-8054 3 - number of errors found. Here they are: 03306 - Coding invalid 000 - - Frozen frame: Error status: 01100000 Error Priority: 0 Error frequency: 8 Internal error counter: 82 Mileage: 165679 km Time display: 0 Date: 2014.05.06 Time: 15:44:30 Frozen frame: Hex value: 0x0002 Hex value: 0x0002 Hex value: 0x32E7 Hex value: 0x25B5 Hex value: 0x007F Hex value: 0x7F80 Hex value: 0x7F00 01042 - Driver uncoded 000 - - Frozen frame: Error status: 01100000 Error Priority: 0 Error frequency: 8 Internal error counter: 82 Mileage: 165679 km Time display: 0 Date: 2014.05.06 Time: 15:44:30 00493 - ESP Sensor Unit (G419) 005 - Lack or incorrect basic settings / adaptation Frozen frame: Error status: 01100000 Error Priority: 0 Error frequency: 8 Internal error counter: 82 Mileage: 165679 km Time display: 0 Date: 2014.05.06 Time: 15:44:30 -------------------------------------------------- ----------------------------- Address 08: Air conditioning (J301) Label file: None Item designation SW: 6R0 820 045 N HW: 6R0 820 045 N Component: Man AC H02 0202 Verification: 0003SH02 VCID: 39781578B0599389EE-806C No errors found. -------------------------------------------------- ----------------------------- Address 09: Electrical central unit (J519) Label file: AKP \ 6R0-937-08x-09.clb Item designation SW: 6R0 937 087 K HW: 6R0 937 087 Component: BCM PQ25 H + 4 H46 0254 Verification: BF046001 Serial number: 0434 082122203 Coding: 3CB02BBF08E1240092380E002C2B0CD00040410F60000000200000000000 Service code: WSC 00788 648 00255 VCID: 45806988CCA1E7699A-8010 Subsystem 1 - Element designation SW: 6R0 959 801 AB HW: 6R0 959 801 AB Label file: 6R0-959-801.CLB Component: J386__TSG_FT 008 1611 Serial number: KU0KU015031200012632 Coding: 18BC30 Subsystem 2 - Designation of the SW element: 6R0 959 802 AD HW: 6R0 959 802 AD Label file: 6R0-959-802.CLB Component: J387__TSG_BT 008 1611 Serial number: KU0KU028031200010088 Coding: 18BC30 Subsystem 3 - Element designation: 1K8 951 171 A Component: DWA-Sensor 00 001 0103 Coding: 000000 Subsystem 4 - Element designation: 1K8 951 605 B Component: LIN BACKUP HO H11 9005 Coding: 000000 Subsystem 5 - Element designation: 1K8 951 171 A Component: DWA-Sensor 00 001 0103 Coding: 000000 Subsystem 6 - Designation of the SW element: 5K0 959 542 C HW: 5K0 959 542 C Component: E221__MFL-TAS H31 0033 Serial number: 0008603 Coding: 020000 Subsystem 7 - Designation of the SW element: 6R0 959 811 G HW: 6R0 959 811 G Component: J388__TSG_HL 008 1611 Serial number: KU0KU021031200014049 Coding: 18BC32 Subsystem 8 - Designation of the SW element: 6R0 959 812 G HW: 6R0 959 812 G Component: J389__TSG_HR 008 1611 Serial number: KU0KU026031200013817 Coding: 18BC32 1 error found: 03444 - Ignition and starter switches 008 - Misunderstood signal - Occasional Frozen frame: Error condition: 00101000 Error Priority: 3 Error frequency: 1 Internal error counter: 120 Mileage: 165679 km Time display: 0 Date: 2014.05.06 Time: 14:02:29 -------------------------------------------------- ----------------------------- Address 15: Airbag (J234) Label file: 5K0-959-655.clb Item designation SW: 6R0 959 655 K HW: 6R0 959 655 K Component: VW10Airbag022 H10 0020 Verification: -------- Serial number: 003GX015S2KM Coding: 003232 Service code: WSC 01383 785 00200 ASAM data set: EV_AirbaVW10BPAVW250 A01001 ROD: EV_AirbaVW10BPAVW250_VW25 VCID: 4A9A5AB4EDBF081177-801E Crash sensor for side airbag on driver's side: Serial number: 3575HRB404R16AM42GPO Crash sensor for side airbag on the passenger side: Serial number: 3585HRB405316AM4892L Crash sensor for the side airbag behind the driver's side: Serial number: 3515RRB405N15TC6792A Crash sensor for side airbag from the rear on the front passenger side: Serial number: 3525RRB405H15TC6KHM3 No errors found. -------------------------------------------------- ----------------------------- Address 17: Indicator kit (J285) Label file: 5K0-920-xxx-17.clb Item designation SW: 6R0 920 860 H HW: 6R0 920 860 H Component: KOMBI H03 0505 Serial number: 0000000000000000 Coding: 140A01 Service code: WSC 00788 648 00255 ASAM data set: EV_Kombi_UDS_VDD_RM09 A04113 ROD: EV_Kombi_UDS_VDD_RM09_A04_VW25 VCID: 39781578B8599389EE-806C No errors found. -------------------------------------------------- ----------------------------- Address 19: CAN Gateway (J533) Label file: 6N0-909-901-6R.clb Item designation SW: 6N0 909 901 HW: 6R0 937 087 Component: GW-K-CAN TP20 H46 0254 Verification: BF046001 Coding: 002200 Service code: WSC 00788 648 00255 VCID: 70EEE85CA3A312C119-8024 No errors found. -------------------------------------------------- ----------------------------- Address 25: Immobilizer (J334) Label file: 5K0-920-xxx-25.clb Item designation SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H03 0505 Serial number: Coding: 000000 Service code: WSC 00000 000 00000 ASAM data set: EV_Immo_UDS_VDD_RM09 A03009 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: 6ADAFA348D7FE81157-803E No errors found. -------------------------------------------------- ----------------------------- Address 44: Steering wheel label file: 6Q0-423-156.clb Element designation: 6R0 423 156 B Component: LenkhilfeTRW V277 Coding: 11250 Service code: WSC 00788 VCID: 2F6C2B20EA1D4D3940-807A No errors found. -------------------------------------------------- ----------------------------- Address 56: Radio (J503) Label file: 5M0-035-1xx-56.clb Item designation SW: 5M0 035 186 J HW: 5M0 035 186 J Component: Radio RCD310 042 0082 Verification: 01000001 Serial number: VWZ1Z2M4098811 Coding: 05000400020001 Service code: WSC 00788 648 00255 VCID: 33642750923569D924-8066 No errors found. End -------------------- (Scanning lasted: 03:15) ---------------------
hello, Can you please help me
ABS 8.2front 6R0 907 379 AB
VW polo 6R 1.6tdi 75
Transmission manual front disc rear drum
WVWZZZ6RZAY076885
LHD
CONFORTLINE
CAYA
Hi ,
I need help to recode ABS/ESP module because coding is: 000000000000000000000000000000000000. (i've changed instrument cluster... )
ESP 8.2i 6r0907379BC
VW Polo 6R
1.4 tfsi 2012 (petrol )
VIN : WWWZZZ6RZCY542259
I use chinise Vag com to recode
Thanks in advance.
Can anybody helm me with ABS coding.
I tried everything, I can’t do it.
Seat Ibiza 1.2 TDI CFWA
Bosch ESP 8.2i
VSSZZZ6JZCR002845
Data/Year 28.06.2011
Manual
Front 256 Disk / Rear 200 drum
Thanks.
Hi my friends could someone help me with skoda roomster1.6 CAYB abs 8.2i pump coding
is left hand,manual transmision,no tmps no start stop
i am ready to pay for your help!!!
here a full scan
Thursday,28,May,2020,16:29:03:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 20.4.0.1
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: TMBNL65J4C7012780 License Plate: SKODA ROOMS
Mileage: 219180km-136192mi Repair Order:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 03 08 09 10 15 17 19 25 44 56
VIN: TMBNL65J4C7012780 Mileage: 219180km-136192miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LM HW: 03L 906 023 LK
Component: 1,6l R4 CR td H33 8791
Revision: --H33--- Serial number:
Coding: 00114016000400080000
Shop #: WSC 13765 031 00123
ASAM Dataset: EV_ECM16TDI02103L906023LM 003005
ROD: EV_ECM16TDI02103L906023LK_SK25.rod
VCID: 7CF741F7F7EB6E665E-8028
No fault code found.
Readiness: 0110 0000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AL HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0001
Revision: --------
Shop #: WSC 13765 790 00122
VCID: 081F2D27BF3332C64A-805C
3 Faults Found:
03306 - Coding Not Valid
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 8
Reset counter: 154
Mileage: 219185 km
Time Indication: 0
Date: 2014.10.19
Time: 02:32:29
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1209
Hex Value: 0x149D
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 154
Mileage: 219185 km
Time Indication: 0
Date: 2014.10.19
Time: 02:32:29
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1211
Hex Value: 0x149D
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 154
Mileage: 219185 km
Time Indication: 0
Date: 2014.10.19
Time: 02:32:29
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1209
Hex Value: 0x149D
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl
Part No SW: 5J0 907 044 C HW: 5J0 907 044 C
Component: Climatronic H08 0103
Revision: K0000000
VCID: 2A5BB7AF45FF20D67C-807E
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 086 H HW: 6R7 937 086 H
Component: PQ25 BCM H12 0022
Revision: -3------ Serial number: 1002480501
Coding: 64980B3808010000003008003E2B08C00000400F6000000000 00
Shop #: WSC 13765 790 00123
VCID: 489FED27FBB3F2C68A-801C
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3241
Serial number: --------------------
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3241
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 811 C HW: 6R0 959 811 C
Component: J388__TSG_HL 002 3241
Coding: 0A0000
Subsystem 4 - Part No SW: 6R0 959 812 C HW: 6R0 959 812 C
Component: J389__TSG_HR 002 3241
Coding: 0A0000
Address 10: Park/Steer Assist (J446) Labels:| 5J0-919-475.clb
Part No SW: 5J0 919 475 HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0003
Revision: --H10--- Serial number: 32901119600156
Coding: 100003
ASAM Dataset: EV_SK25XParkiAssis2 S01002
ROD: EV_SK25XParkiAssis2.rod
VCID: 72EB6FCFA5AF281604-8026
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 6R0 959 655 L HW: 6R0 959 655 L
Component: VW10AirbagTB3 H09 0020
Revision: -------- Serial number: 003GY00446UB
Coding: 004233
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4B95D22BE2C519DEA7-801E
Crash sensor for side airbag: driver side:
Serial number: 3495RRB404R0N3MO7G45
Crash sensor for side airbag: front passenger side:
Serial number: 3505RRB405T0N3MOI966
Crash sensor for side airbag: rear: driver side:
Serial number: 3515RRB405B0M98E5HJL
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525RRB405B0M98E8PGU
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5J0 920 811 J HW: 5J0 920 811 J
Component: KOMBI H04 0206
Serial number: 00000007614873
Coding: 120A00
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
VCID: 2E53BBBF71174CF6A0-807A
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R7 937 086 H
Component: GW-K-CAN TP20 0022
Revision: -3------
Coding: 832200
VCID: 70EF65C7A3A31A06F2-8024
Address 25: Immobilizer (J285) Labels: 5J0-920-xxx-25.clb
Component: IMMO H04 0014
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
ROD: EV_ImmobUDSJCIPQ25_VW25.rod
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00140
Shop #: WSC 00000
VCID: 397998E324599B4E05-806C
1 Fault Found:
00816 - Power Steering Sensor (G250)
30-00 - Open or Short to Plus
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5J0 035 161 D HW: 5J0 035 161 D
Component: Radio-SWING 001 0003
Revision: -----03S Serial number: SKZ4Z2L1305043
Coding: 0D0004000006
VCID: 23455A8B22D5F19E3F-8076
End-------------------------(Elapsed Time: 02:10)--------------------------
Hello
Please help me with long coding ABS Skoda Fabia
VIN: TMBEL65J6B3007098
Adres 01: Silnik (J623-CAYC) Plik etykiet:. 03L-906-023-CAY.clb
Oznaczenie elementu SW: 03L 906 023 DN HW: 03L 906 023 DL
Komponent: 1,6l R4 CR td H13 9970
Weryfikacja: --H13--- Numer seryjny:
Kodowanie: 00114016002400080000
Kod serwisu: WSC 13765 031 00016
Zbiˇr danych ASAM: EV_ECM16TDI02103L906023DN 003007
ROD: EV_ECM16TDI02103L906023AH_003.rod
VCID: 75B7E7418540D0FFEA0-8020
Adres 03: ABS/hamulce (J104) Plik etykiet:. 6R0-907-37x-ESP82.clb
Oznaczenie elementu SW: 6R0 907 379 AA HW: 6R0 907 379 AF
Komponent: ESP8.2i front H05 0003
Weryfikacja: --------
Kodowanie: 000000000000000000000000000000000000
Kod serwisu: WSC 33361 790 00048
VCID: 7DA7FF61BDB088BFA20-8028
huachoa3 (12th May, 2022)
hi frends need help
https://www.digital-kaos.co.uk/forum...7379bc+esp8.21
PRESS THANKS AND REPUTATIONS (STAR) BUTTON
I don't give others the password to the file. I'll send my file and I'll try to make it
Hey help me someone with ABS vw polo 6r coding
6R0907379AD
vin: WVWZZZ6RZAY096673
