Page 32 of 33 FirstFirst ... 2227282930313233 LastLast
Results 466 to 480 of 482
  1. #466
    Jul 2016
    Vilnius
    Quote Originally Posted by carsinlet View Post
    Hi please can you calculate me a long code for a vw golf R4 1.6 TDI CAYC MK60ED 1K0907379BA RHD WVWZZZ1KZAW090175. DONT THINK HAS STOP START TPMS ASR/ESP HILL HOLD, THANK YOU.
    Your module is actually MK60EC1... So you're at wrong thread
    * MK100
  2. #467
    Mar 2014
    Please help me with long coding for ABS 8.2 front
    Skoda Fabia 2012 CAYA
    6R0907379AB
    VIN: TMBES25J2C3132175
  3. #468
    Apr 2021
    Quote Originally Posted by cudzy View Post
    6R0907379AB
    In your box. Have a good day
  4. The Following User Says Thank You to r4nd0mize For This Useful Post:
    cudzy (8th September, 2023)
  5. #469
    Dec 2015
    Romania
    Hi guys i need long code abs vw polo 6r 2012 for this vin changed cluster
    WVWZZZ6RZCU079232
    esp 8.2i front
    part number 6r0907379bc
    hardware 6r0907379af
    Thanks in advance.
  6. #470
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Default Longcoding ABS Pump
    Howzit
    I need longcoding for ABS pump for this 2010 VW POLO 6R CLP engine
    Attached scan with VCDS VIN number is AAVZZZ6RZAU022175
    Right hand drive version
    'If I helped, please click Thanks +Reputation.. !'
  7. #471
    Nov 2023
    Arequipa
    I am Rei from peru, new to this Forum
    please help me with ABS Long coding for:
    VW Jetta 2009
    VIN:
    3VWRM71K09M005808
    ENGINE = CBT08177
    I'm thankful
  8. #472
    Feb 2016
    SEAT IBIZA 2010
    Old module 6R0907379AB
    New 6R0907379S
    The new one does not accept the old code: 100200DB006F00BB082500EB00D600000000
    VIN: VSSZZZ6JZAR029095
    Do you have an idea why the code doesn't work?
  9. #473
    May 2016
    Seat Ibiza 6J 1.4 BXW LHD
    6R0907379
    VIN: VSSZZZ6JZ9R085525
    Without tpms
  10. #474
    Apr 2021
    Quote Originally Posted by yaroliban View Post
    6R0907379
    Without tpms
    Info about transmission type and rear brake would be helpful,... and if that car maybe has engine start stop feature.
  11. #475
    Apr 2021
    Quote Originally Posted by wojtek2 View Post
    SEAT IBIZA 2010
    New 6R0907379S
    That is because the "S" software is incompatible with Ibiza.
  12. #476
    Nov 2014
    Turkey / İstanbul
    Default VW Golg 6 2010 ESp Error I need long code
    Hello I have 2010 VW Golf 1.6 102 Hp
    Car has ESP Error
    Normally car has 1K0614517BK abs module
    When I connect it is showing 1K0907379AP
    Vin number is WWWZZZ1K********
    113B200D092700FB881204E7902000423100 long coding
    that is abs coding right now,who can check codiing file is correct or not.
  13. #477
    Apr 2021
    Quote Originally Posted by ayhanozdemir1982 View Post
    Car has ESP Error
    If it originally had BK part number ending for the ABS system, then AP is more or less a downgrade. But doesn't mean it's inoperable with the car.
    Biggest problem here is, that the coding doesn't fit. Coding is not ok, it is different than the vehicle settings.
  14. #478
    Mar 2016
    Skoda RAPID 2014
    1S0614117Q
    VIN:
  15. #479
    Nov 2018
    Minecraft
    Default 2x VW Polo 6R 2013: Coding got wiped when they swapped the cluster.
    Some client swapped clusters in 2 cars, both VW Polo 6R 2013.
    Now in both cars ABS coding is gone.
    See attached scans from both cars VCDS.
    Car 1:
    VIN: WVWZZZ6RZDY231929
    Chassis Type: 6R-VW25 (6N0)
    Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
    Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
    Component: ESP9.0i front H02 0002
    Serial number: --------------
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 01383 785 00200
    ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
    ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
    VCID: 0F7BB32177DE92A36E9-805A
    Car 2:
    VIN: WVWZZZ6RZDY214226
    Could somebody help me with long coding?
  16. #480
    Jun 2022
    Hello
    Have polo with bosch8.2i .
    Car is japan import.
    Customer fit UK clocks and abs coding was set to 00000000.....
    When came to car Autel couldnt connect to abs .
    After that tried odis online it tried but couldnt do it.
    Now autel can comunicate with car but not accepting code from Esp Calculator
    Car vin number WVWZZZ6RZAU022722
    ABS part number 6R0907379R
    engine code CGGB
    Abs Coding by calculator 210228C2416F00B4842C14E482D300400700
    my change is rhd steering and tpms and hill assist 210228C2416F00B4842C14E482D300800300
    None of codes accepted.
    Can someone help with this one?
    My option is try to reflash abs module as looks like issue is there...
