Results 1 to 15 of 28
    Top Poster + randomlog's Avatar
    Argentina
    Default A4 B6 - Engine Start Blocked by Immobilizer
    hi my friends, how are you?
    Yesterday i tried to turn on my a4 b6, but the immo has blocked it after 2 o 3 seconds.
    a little of history, in 2012 the water has suck my motor, so , after 18 months, the motor works again.
    Well, i get some errors in engine and instruments modules
    Engine Module:
    18056 - PowerTrain Data Bus
    P1648 - 004 - Failure
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 008 -
    Instruments Module:
    01314 - Engine Control Module
    49 - 00 - No communications.
    i attach one picture of errores.
    When the car Start in dashboard i can see:
    abs light on
    esp light on
    rpm, km doesnt work
    i hope your help!!
    Thanks in advanced.
    Admin of Audi Forum Argentina.
    metercar's Avatar
    May 2011
    Argentina
    check fuses friend, wiring and gateway module
    on a rich or poor discussion - PL & SP blood - only on bench
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Dash and ECU are not connected.You need to check K-Line,I think that there is your problem.Get wiring data for your car and start from there.
  4. The Following User Says Thank You to simaservis1108 For This Useful Post:
    sv2hqx (14th November, 2014)
    Argentina
    Thanks, OK this night i'll try to check fuses, battery voltage, ground, and another wires.
    i need resolve this issue fast to go to home, if i can disable immo from dashboard bin, the car would start engine ok?.
    EDIT:
    I'm watching a video of the dashboard but the IMMO light does not turn on.
    Aug 2013
    Serbia,Belgrade
    Does check engine light turn on?
  7. The Following User Says Thank You to simaservis1108 For This Useful Post:
  8. #6
    Argentina
    Quote Originally Posted by simaservis1108 View Post
    Nop, check engine light off.
  9. #7
    super jumbe's Avatar
    Livingstone
    From my last experiment remove ecu plug from car, for few min replace and try again.
  10. #8
    achaccha's Avatar
    Nov 2010
    From what I see you have a problem with the engine ecu. it may be that it lacks 12V power feed or maybe lacks ground. well check fuses and wiring first. so long without work may be that the rat ate the wires
    luck
  11. #9
    Aug 2013
    Serbia,Belgrade
    Definitely check K-Line.Wiring is the problem for sure.
  12. The Following User Says Thank You to simaservis1108 For This Useful Post:
  13. #10
    Argentina
    Hi, here you have a video of yesterday
  14. #11
    electrones's Avatar
    Feb 2012
    Around C.V
    Hi friend
    Check fuses, wiring, main relay for ecu and k-line , strange immo light doesn't work too.
    Scans in all modules to see DTCs.
    Cheers
    Press "THANKS" button. just one click, CHEERS
  15. #12
    Argentina
    Quote Originally Posted by electrones View Post
    Hi friend
    Cheers
    hi thanks for your help, where are main relay for ECU and K-line please?.
  16. #13
    Argentina
    hi ,we tried with another ecu without immo and car start OK.
    can anyone remove immo of my dump?.
  17. #14
    cjawahir's Avatar
    T&T
    hi here is immo off for your ecu , let me know if it work
    its strange that i dont see engine check light on dash , but you did scan both the cluster and engine ecu .
    cj
  18. The Following User Says Thank You to cjawahir For This Useful Post:
    Meat-Head (29th July, 2014)
  19. #15
    Argentina
    Quote Originally Posted by cjawahir View Post
    cj
    hi, thanks i?ll check tomorrow.
    How you can disable immo?.
    Yesterday i made a dashboard test with vag and the IMMO LIGHT / CHECK ENGINE never turn on... others light turn on OK. (thats normal?) i dont remember if anytime i saw immo light turn on in this car :/
    we tried with another 1.8T ecu and car start ok, dashboard rpm ok, km ok, temp ok, tank ok, fis ok.
