Corrupt dump, you can try pin 01129 adapt over channel 50.
Keep in mind, English is not my native language.
Can someone please change the immo data on Visteon Cluster 1K0920862A 95160 (attached) ?
Cluster immo data read with vcds:
WVWZZZ1KZ6W018332
VWZBZ0E0203368
Is it possible to change the immo data on cluster with this data ?
read from engine ecu;
VWZBZ0E0173547
WVWZZZ1KZ6W073247
CS: 47 9E 5A 98 59 ED 17
MAC: 1A F9 E6 8C
PIN 1585
POWER CLASS: 42
Last edited by gsmflasch; 14th January, 2022 at 12:14 PM. Reason: cluster data edit
yes, it's possible
@gsmflash: The eeprom you posted contains the following immo:
VIN: WVWZZZ1KZ6W073247
IMMOID: VWZBZ0E0173547
CS: 479E5A9859ED17
PIN: 01585
MAC: 1AF9E68C
PC: 42
KEY1: 9CC6495B
KEY2: 51B56EEA
KEY3: FFFFFFFF
KEY4: FFFFFFFF
This seems to be the exact immo from your engine ecu!
I think you uploaded the wrong file?
Upload the correct file, or the correct immo data to insert in this file.
Rgs H2Deetoo
gsmflasch (15th January, 2022)
@elektoni, the immo data from your cluster is:
PARTNO: 1K0920863A
VIN: WVWZZZ1KZ7W072241
IMMOID: VWZBZ0F0391407
CS: E1C54DDF02BE68
PIN: 01663
MAC: E8361446
PC: 42
KEY1: 211F6AAF
KEY2: FFFFFFFF
KEY3: FFFFFFFF
KEY4: FFFFFFFF
Rgs H2Deetoo
elektoni (15th January, 2022)
Can someone please the immo data Cluster 1K0920862J EEPROM 95320
Who can help with pin code.Thanks
Here is your immo data:
VIN: WVWZZZ1KZ6W585837
IMMOID: VWZBZ0E0266490
CS: F8D12D91C27A13
PIN: 06064
ECU MAC: AC45
CLUSTER MAC: 98CA
MAC: 98CAAC45
PC: 5B
KEY1: 5FE168C1
KEY2: D5BDBDE8
KEY3: B0018EB2
Rgs H2Deetoo
pin does not fit
100% sure my info is correct.
What do you want to use the PIN for anyway?
replace dashboard
I don't think the new cluster can be adapted using that PIN method.
Afaik that PIN method is only for very old clusters.
