Can you suggest a solution.Thanks
I guess this Visteon cluster is your replacement cluster?
If so what is your original cluster? If you have already read immo please post it here as a file you read preferably.
(If I'm wrong about orig and target cluster please post all details here then.)
Rgs H2Deetoo
new dashboard 1K0920871A carprog obd dump
Here is your immo block for new cluster with your orig immo inserted.
Please test and report!
Rgs H2Deetoo
Thank you works perfect.
Yeah :-D
Good to hear it works fine!
RAMA2 (20th February, 2023)
Hello Soxten!
I have problem with conecting with Jlink. I can't conect and I don't know why.
Maybe my Jlink project isn't good. I lift RESET pin and no work.I use external 12 volts power.
Can you help me with better conections and Jlink good project?
I this picures you have blank pin name and I don't know what is it.
Majone
good, thanks.
Good morning everyone. Can I ask those involved here to look at my similar problem here in the thread ? I don't have a 95160, but I do have a 95320 eeprom. Alarm clocks 1K0920864B. Very thanks.
https://www.digital-kaos.co.uk/forum...e-to-new-95320
Hola, H2Deetoo, ¿puedes decodificar 95160 Visteon eeprom y obtener immo data cs, pin mac, power class? Desde ya muchas gracias https://drive.google.com/file/d/181gAq8ZBZGs2idSv8ng0EOTNSfSH02RQ/view?usp=sharing
Inglese por favor!
Here is your immo data:
VIN: WVWZZZ1KZ6W051050
IMMOID: VWZBZ0E0252406
CS: EFCD4B5BA466F2
PIN: 01425
ECU MAC: 6B2F
CLUSTER MAC: 0241
MAC: 02416B2F
PC: 37
KEY1: 3FFF5CB1
KEY2: 6E455DB1
Rgs H2Deetoo
RAMA2 (21st February, 2023)
Thank you for your time and kindness H2Deetoo you are a crack, I don't speak English and thanks to the googlr translator I can communicate !!!
Good afternoon. Help with the dump eeprom.
Replacing the tidy Magnetti Marelli 1k0920 854 with Vdo 1k0920 862J. I attach the Vdo dump and data from MM
Magnetti Marelli
VIN = WVWZZZ1KZ9W133662
IMMOID = VWX5Z0H8242033
CS = 9AF409C935E813
PC = 37
PIN = 10899
MAC = DDB41C8B
TPID1 = 3FAC8CB5
TPID2 = 352A8DB5
To transfer immo data to VDO cluster you need to do it by OBD using suitable tool.
You cannot do it by eeprom only.
I have carprog, can not put keys.
In vcds 50 channel close, pin correct
