Results 1 to 4 of 4
    Default storing satellitrs in vu+ duo
    hi, could somebody help first 1 of these boxes . trying to store sats used sat finder to pick up sat, all channels on, but when move to another sat nothing stored when you go back, you have to search again, nothing in manual to tell you how to store them, thanks peter
    digicon's Avatar
    you could always install a pre-made channel list from Cateys for example: http://www.digital-kaos.co.uk/forums...ml#post2341058
    oryou could use the Vhannibal Plugin autoupdater for your channel list: http://www.digital-kaos.co.uk/forums...plugin-413614/
    Default storing satellites
    box came with everything on it , just need to store sats with urals, thanks
    digicon's Avatar
    Quote Originally Posted by lochside View Post
    If it came with 'Everything on it' then why does it not have the satellites pre-stored you require.
    If your using USALS then Tuner Configuration - Simple - Positioner and then enter your USALS co-ordinates
