Results 1 to 5 of 5
    Aug 2013
    Default dpf mercedes sprinter 3.18 cdi
    Hello everyone can you help me to remove the dpf to this sprinter cdi 3.18
    thanks to all in advance
    DK Veteran velindro's Avatar
    Portugal
    Default sprinter
    try and report,but should be fine
    Aug 2013
    thank you very much Velindro soon as I try I know
    Aug 2013
    Hello Velindro I noticed that the file that you gave me is made with volta sensor, the software I have it too, I wanted to see if there are other solutions, you have it tested? however many thanks for your trouble.
    greetings Sisco
    Germany
    try and report,pass PM.
    disconnect connector from temperatur sensof and sensor diff.pressure
    Best regards Eddy
