Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Mar 2014
    Default R270 Repair guide
    There is a lot r270 which is order from china which not work. I bought too and test it doesn't read ezs 1j35d, it give unknown pin error. After looking in this motherboard I saw something.
    Pin 2 is 12V, pin 26 is gnd, when I check with multimeter there is no voltage. One strange think is that when I plug adapter 12V to r270 and check with multimetet it have voltage for 1 second then it gone. After I disconect adapter and connect again it have again voltage but for 1 second. Then now I see, every time when I plug adapter it have voltage for 1 second and it's gone. Maybe there is users which good electronic knowledge, which parts can be problematic and give this problem with voltage to apper for 1 second and gone, every time when plug adapter, here is picture of board. Thanks.
    DK Veteran gjuzel's Avatar
    Nov 2011
    (North Macedonia)
    mozda je i to neznam ali pstoje 3 razlicite plocice.3 diferent motherboard
    Mar 2014
    Napon nestaje, svaki put kada istekas i ustekas pojavi se za sekundu. This is motherbard same like other which work, but there is some element which not work and voltage appear for second and gone, maybe some with good electronic knwoledge can give opinion.
    Nov 2011
    friend and friend
    While you have precionar desalida connector while reading and everything works fine
    Mar 2014
    Quote Originally Posted by arvedo View Post
    I am not understand, you mean voltage stabilisity?
    I check adapter it have 12V.
    Nov 2011
    friend and friend
    Pressing cable outlets, I can help.
    I have this bug
    I fix it and doing pressure output connector
    Mar 2014
    If I good understaned problem is in cable, but I check voltage also on connector witohut cables and in connectors alo same thing, when I check with multimeter direct on connector.
    Mar 2014
    arvedo You can share with us for fix this solution if you tell that know, this will be helpful for all users, there is a lot r270 programmer which not work, thanks.
    Nov 2011
    (North Macedonia)
    change voltage stabilizator.promen stabilizator 5v da ne on nesto kurca.recimi koju atmegu je unutar kao sto vidim plocicu tvoja je ona sta mnogima ne rade .nemas onu diodu.pozz
    Mar 2014
    Atmega AU1325, kupio sam ovaj crni jer je skuplji i misio da ce bolje raditi, a na svim plocama vidin u ostalim temama fali dioda.
    I bought this black boy beacuse it be expensive and I think that's better what's expensive but no. There missing d1 and d3, c28, r10, some element ds1 but on other board which work missing too.
    Nov 2011
    (North Macedonia)
    ok na moju plocicu ima dioda pa radi izvrsno.neznam !??ok on my plate has a diode and works great..back to the Chinese..ja sam vratio superag 2.0 reparirali su ga i vratili natrag sad je ok...kolko ce da kosta iz bosne neznam ..from macedonia to send china 5 euro sending
    Mar 2014
    Iz bosne je skuplje, ne isplati se to i dok ponovo cekam da dodje, probacu nekako sam napraviti pa ako uspijem bit ce dobro i za ostale korisnike.
    From Bosnia send to China 20eur, don't have time again to lose with this, I will try to repair myself, element per element.
  13. #13
    Mar 2014
    Here is picture from dk board is same like mine and it work for this user, so think problem on mine is some element..
  14. #14
    Mar 2014
    So I test now this, on my board is there is capacitor c20, but on working one there is no capacitor on that place, now I don't know is that capacitor on mine board be good solder but when I remove this capacitor I have bip bip, when I put back capacitor I don't have bip bip like don't connect and r270 can't recognize, so continue to see different.
  15. #15
    Nov 2011
    (North Macedonia)
    pgledaj slike [ATTACH]271290 2 and 26 pin 6.52 volt
  16. The Following User Says Thank You to gjuzel For This Useful Post:
    ecupro (3rd August, 2014)
