Results 1 to 15 of 19
    Oct 2010
    EU
    Default Ford Focus 1.6 CDTi, EDC16C34 - 0281011701 - eeprom 95160 corrupted
    please corret my dump from Ford Focus 1.6CDTi
    EDC16C34
    0281011701
    Fault codes:
    P1603 - EEPROM Data Corrupted
    P1621 - immobiliser codes do not match
    Many thanks in advance!
    DK Veteran zeljolaki's Avatar
    In my garage
    Try this dump ...
    WW
    dont put zeljolaki dump, is from another car, read dasboard dump and post here, i cant recover sync bits from ecu dump
  4. The Following User Says Thank You to elephantul For This Useful Post:
    Pali33 (5th August, 2014)
    Oct 2010
    EU
    Default dash dump
    here the dash dump (MC9S12XHZ512VAL, 1M80F)
    WW
    taft, dump have another structure, try this pass pm
  7. The Following User Says Thank You to elephantul For This Useful Post:
    Pali33 (11th August, 2014)
  8. #6
    Oct 2010
    EU
    ... i have try it. Not work. Fault code P1603 - EEPROM malfunction / identification number not registered (the same fault code like before)
    Have you any other idea? I can try it one more time.
    regards
  9. #7
    WW
    now have both error or only p1603 ? ecu eprom is pair with ecu flash, when eprom is corupt is posibiliti to corupt pair flash eprom, read engine ecu flash bdm
  10. #8
    Oct 2010
    EU
    now is only P1603 ... here the ECU flash:
  11. The Following User Says Thank You to Pali33 For This Useful Post:
    br.balazs (6th July, 2016)
  12. #9
    WW
    try again .........
  13. The Following User Says Thank You to elephantul For This Useful Post:
    Pali33 (21st August, 2014)
  14. #10
    Mar 2009
    Hi Pali33 did you ever resolve your problem? I have the same problem with this ecu.
  15. #11
    Oct 2010
    EU
    no, it have not work for me.
    Anyway, big thank to ELEPHANTUL.
  16. The Following User Says Thank You to Pali33 For This Useful Post:
    m3evo (1st September, 2014)
  17. #12
    Mar 2009
    No probs thanks for getting back to me.
  18. #13
    here
    pnly with ids you can resolve your pb
  19. #14
    Mar 2009
    You mean Virginise ecu and re sync?
  20. #15
    Mar 2009
    Quote Originally Posted by smt View Post
    Do you mean to make ecu virgin and re sync with ids?
