Make please dpf egr off
Toyota, Hino, Kubota mod files for free by ATR software. You can upload your files here for dpf, egr or dtc modifications. All ECU's except Denso. For other files, please PM.
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
Hino only 300, 500, 700. Ecu Denso N04C-UV, J08E-UR, E13C-TL and E13C-TR. Your ecu do not have in a list.
Many dpf solutions i try dont work from atr sometimes car dont start sometimes dpf problem again
IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
No friend i don't have it byt that is irelevant i try several files worked some dont one not start
leave it i dont whant explainings here these was my mistake mention that
every soft have bygs that was i like to say
cheers
Support working online, all solutions by hands, if something wrong, they can repair it. Files without cheksum, do not forget it.
Can you make my file via support?
I can try.
is dpf off possible thanks
Hello could you check if its possible DPF - EGR - STAGE1 for this hino 500?
