Results 16 to 30 of 36
  1. #16
    BiH Kiseljak
    Measure input and output voltage. it should have 5v output voltage. Try to lift from pcb littlebit. I had similar problem, and problem was bad pcb design.
  2. The Following User Says Thank You to pecirepi For This Useful Post:
    Fec001 (15th August, 2014)
  3. #17
    Fec001's Avatar
    Max232 was getting hotter with the regulator too. Now change regulator and max232 it seems ok now, no hot units but pc still not found programmer. I read something about serial cable problem. I tried with standard cable where pin 1 go to pin 1 and so on. Should I use another pinout?
  4. #18
    Fec001's Avatar
    Quote Originally Posted by ecupro View Post
    U10 seems really burned.
    I think U10 is fine.
  5. #19
    Mar 2014
    Quote Originally Posted by Fec001 View Post
    That in red circle is resistor.
  6. #20
    Mar 2014
    I mean about this ic, it seems burned.
  7. #21
    Fec001's Avatar
    No, it looks fine. Just bad picture quality
  8. #22
    Fec001's Avatar
    Finally Pc recognize programmer. It was RS232 cable fault. Other problem I still cannot write flash memory. It writes eprom content perfectly.
  9. #23
    morocco/fbs
    chek your cable first see at etl port com you can see where is the prob you must swap pin in com port cable
  10. #24
    Fec001's Avatar
    But it can write eeprom content of MCU. Don't believe it's still cable problem. Monday will post pictures abou problem
  11. #25
    Fec001's Avatar
    is the 4J74Y exchangeable with 2J74Y? Becuase I have 2J74Y what can be programable flash/eprom with ETL. 4J74Y flash cannot program with ETL. Maybe MCU is faulty....
  12. #26
    gwee's Avatar
    Dec 2012
    unknown
    yes can do, 2j74y always giving problem.
    try heating up the mcu and read
  13. #27
    Nov 2012
    Hey guys, where can I purchase this programmer?
  14. #28
    Nov 2012
    I finally got ETL 908 Clone and I have problem with 4J74Y too. Programmer can't read it. With other masks everything is fine. maybe its a hardware problem? maybe faulty resistor or condensator?
  15. #29
    gogalv's Avatar
    Aug 2010
    You'll need pictures from all sides mate .... ? PremierD
  16. #30
    Nov 2012
    Hey guys so I bought exactly same ETL programmer and now I get same error on both programmers:
    "Reset line must be in high state"
    Both programmers say this.
    on two same chips(2J74Y and 4J74Y) other chips are read perfectly.
    tried on other PCs.
    tried with different cables.
    any solution?
