Results 1 to 8 of 8
    Fec001's Avatar
    Default Ford Galaxy 2.0 TDCi DPF off check
    Can someone check if DPF and EGR are switched off in this dump? Customer bring car with drilled DPF and he want to restore original state, he bought a new DPF and EGR
    SID 206
    Thanks!!
    Jul 2012
    you have checked the values ​​with diagnosis ??
    I think it still works egr controls
    Fec001's Avatar
    checked with diag. ECU is still controls EGR so I think it's good. another thing is DPF can someone check that?
    Jul 2012
    Quote Originally Posted by Fec001 View Post
    dpf has been removed egr on
  5. The Following User Says Thank You to mario38 For This Useful Post:
    Fec001 (13th August, 2014)
    Fec001's Avatar
    If I write another flash with the same part nr. is that ok? or there is immo data in flash?
    Fec001's Avatar
    Solved by very helpful member ludbe!!!!
    Sep 2010
    Fec001: Does this dpfoff solution worked correctly ?
    Fec001's Avatar
    hmmm don't know because customer brought this car about 2 weeks ago and he bought new parts immediately and built those in
