Results 1 to 5 of 5
    Mar 2014
    Default Digital TV problems
    Hi I don't know if this is right place but ive got a skybox f5s working on my TV downstairs i have a UHF modulater connected to the skybox f5s as i have 2 TV's upstairs where i can watch the channels from skybox f5s but the digital tv upstairs keeps pixelating any body got any idea what can be the problem please
    Member billybob69's Avatar
    Jun 2008
    The first thing that you need to do is to check whether the connections are all OK. Secondly establish whether you have got a good signal going to your TV. There should be something in the TV setup which tells you what % strength of signal you are receiving (most need at least 75%). If you have got a good signal, I would connect your skybox to your upstairs cable to see if your skybox also pixelates on that cable, if it doesn't you know that it is a problem with how your TV transcodes the signal.
    bb69
    Mar 2014
    Quote Originally Posted by billybob69 View Post
    bb69
    Thank you i have tried these and still stuck i wish i could take a pic the way everything is set up i have a good signal strength i have Hdmi cable from skybox f5s to Tv downstairs & the coax from the main aerial into a splitter with a rf lead in to main tv downstairs the other end of rf into modulator there is another coax from modulator to a signal booster upstairs then a coax from each of 2 other tvs upstairs to booster and finally i have a scart from modulator to skybox f5s Thank you for replying
    DK Veteran ontherack's Avatar
    Apr 2011
    Does box output from hdmi and scart at same time??? You are switching from hdmi/scart as required???
    DK Veteran WOODWARD395's Avatar
    Manchester UK
    are you using both TV'S together Always thought you could only have hdmi output or scart from your box but not both together may be wrong. I had a similar problem many moons ago using a modulator simple test with your tv on downstairs see how it pixalates then turn your tv off downstairs and see if it is still doing it.
