Results 1 to 12 of 12
    spychu14's Avatar
    May 2011
    POLAND
    Default Need BDM readout SCANIA R500 2008 E5 EMS6. 1726098 PDG02091Q
    I need BDM readout or BDM + OBD2 to compare EMS6 Scania R500 2008 E5
    HW : 1726098 SW : 1549, 1549734
    ECU ID :
    EMS S6 DC1606 L01
    XLER4X20005190800
    1726098
    Scania
    070930
    PDG02091Q
    1874470
    110528
    1549734
    1874502
    1874461
    1874534
    Even any other EMS6 BDM readout would be helpful. After OBD flash, mpc is erased.
    paczka.rar
    VAG
    Aug 2013
    ciao ho questo vedere se aiuta
  3. The Following User Says Thank You to sisco1 For This Useful Post:
    Autronic (24th November, 2017)
    DK Veteran 70max's Avatar
    May 2012
    Quote Originally Posted by sisco1 View Post
    Hi friend
    you should write in English
    use google translator is not the best
    but it works.
    ciao amico
    ti conviene scrivere in Inglese
    usa google traduttore non ? il massimo
    ma funziona.
    Saluti max
    Aug 2013
    Quote Originally Posted by 70max View Post
    Hi friend
    but it works.
    ciao amico
    ma funziona.
    Saluti max
    hello friend I used google translator
    Aug 2013
    Quote Originally Posted by spychu14 View Post
    ECU ID :
    EMS S6 DC1606 L01
    XLER4X20005190800
    1726098
    Scania
    070930
    PDG02091Q
    1874470
    110528
    1549734
    1874502
    1874461
    1874534
    paczka.rar
    hello which tool you used to write from obd?
    spychu14's Avatar
    May 2011
    POLAND
    Everything is ok now. Very easy to repair by obd
    VAG
    Aug 2013
    how did you do? you've written the file again before bed and everything went okay?
    spychu14's Avatar
    May 2011
    POLAND
    Just write ori file without ECU ID.
    VAG
  10. #9
    Babos's Avatar
    Mar 2012
    How you read full via BDM?
    I try read EMS 6 Motorrola from scania but can read good only eeprom flash read only FFFFFF.
    It is look is emty or tool use wrong driver for read that flash!
    I try read and use Fgtech V48 and 54 result is same.
    Maybe some one have expireance with that ecus from scania?
  11. #10
    spychu14's Avatar
    May 2011
    POLAND
    Some say that only ori cmd can read by bdm this ecu.
    VAG
  12. #11
    Aug 2013
    I have only read about but never written I used FGTech 48 controls the file that I posted above is good?
  13. #12
    Babos's Avatar
    Mar 2012
    I dont know i not see before that files but inside is info in my MPC i have only FFFFFF
