Results 1 to 5 of 5
    DK Veteran 70max's Avatar
    May 2012
    Default PLEASE HELP egr OFF edc16C34 Citroen C3 1_4 HP68
    Hi friends,
    please help problem in this car:
    I attach the file to read for advice if mod is good
    EGR and closed properly.
    The car goes in recovery and should go out to work well again,
    but often goes out with error message:
    Anti-pollution Fault System.
    But with the diagnosis do not see any error message about this,
    I only found errors in the low-pressure fuel circuit,
    but I think this occurs when you turn off the car.
    I tried the bit of anti-pollution control but I can not find it.
    If anyone can help me kindly
    to eliminate this problem.
    Thanks in advance to all.
    Jul 2012
    I believe that egr is not off properly.
    but if egr is not working can cause a problem ..
    off the egr opens and read dtc error .. if you delete this egr not other problems
  3. The Following User Says Thank You to mario38 For This Useful Post:
    70max (15th August, 2014)
    May 2012
    Thanks for your reply,
    Give me some advice how to close properly egr
    Apr 2012
    Hi, here you have your mod, with egr off
    pass in PM
  6. The Following User Says Thank You to dean 21 For This Useful Post:
    May 2012
    Quote Originally Posted by dean 21 View Post
    pass in PM
    Thank you dean21
    I'll try tomorrow Saturday
    and place the result.
    best regards Max
