Results 1 to 5 of 5
    Nov 2009
    UK
    Default transit connect 1.8 TDCi 2008 immobelised
    Need help with this van please
    Dont crank, immobeliser led staying on. Flash cose 23
    Engine fault codes
    P1602-78 Immobilizer/ECM communication error
    Instruement
    B2139-60 the pcm identification was not recognised by the pats module. status byte 60
    3960 unknown fault code
    key programming works ok. erased all keys and programmed 2 keys ok. but noticed that when in key programming all the ignition lights go off , although prog succesfull. As soon as you go out of key programming the dash lights come back on. Tried on an earlier model with separate pats module and the dash stays on. Dont know if this is normal.
    Do you think ecu or dash are faulty, although we have comms or just needs pairing. What tool apart from IDS can we use for pairing, i know the normal diagnostics equipment dont have this function.
    Nov 2009
    UK
    Any ideas of possible cause or what else i should check ?
  4. The Following User Says Thank You to solar For This Useful Post:
    yusef (17th August, 2014)
    Nov 2009
    UK
    Hi Solar
    Thanks for that , it worked great and immo now matched and immo light going off and cranking ok, firing with easy startis
    Not starting , coming with fault code
    P0003 fuel volume regulator circuit low
    is this to do with cut off solenoid ? how/what do i check ?
  6. #5
    Sep 2009
    Hello. I have similar problem. Ford toneo connect 2010. No immo errors in dash. Only in ECU B1622. Dash and ECU eeproms here. Starter work. Engine no start.
