Hi, use your mod flash file,and put in bdm backup file, car will start. Ecu have a problem, only that solution works.
Hi guys, plz help me with solution
If I try to write modified file car not start and no comm to ecu
I have full bdm backup when i write backup car starts
I try writing modified file trough bdm car not starting, same trough OBD with MPPS and FGTECH .... writing process OK with no errors and car not starting.
Checksumm is OK , tried checksumm trough BDM and no change
Any help will be appreciated
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination.
imported mod file into full bdm read .... car don't start
(\__/)
Post original and mod... maybe you had made something wrong.
if i make just a small change for example +1 in just one cell in drivers wish car don't start
(\__/)
read with mpps the soft,and remap these...with bdm you readed full software and maybe when was remapped,the immo was touched...so,using mpps,you use only the part of maps...
Please explain better this situation...
Wich file you call "ori"? BDM? And maybe you had mod this ori and write through BDM again? Have you started the car between read and write?
Betrescudan said already, that i meant...
ori i call BDM read .... ecu stays on table the whole time ... write mod back trough BDM and car don't start after that.
car starts always if i write complete BDM backup
i read with fgtech ... mod write back car dont start
i read with mpps ... mod write back and car dont start
ecu not responding to diag equipment after any modification to flash
(\__/)
Strange... never had such a problem...
Sorry, i can't help you.
If you read with MPPS and write this file again, the car start?
so you read first with bdm...remap....not work
another read with fgtech...other remap for these file....not work
another read with mpps...another remap...not work............please change the tuner...or post the orig readed with mpps...we will try to help you
it is not tuner related .... if i mod just one map one cell +1 ... car don't start ... i don't have the files on this PC
(\__/)
haven't tried that ... will try tommorow
here are files
(\__/)
files both are good ...i make a map with titanium with cecksum ok for the bdm readed
