Results 1 to 10 of 10
    Default toyota yaris 2006 smart key reset solution
    hello
    i got a toyota yaris with smart keys lost
    as GWE said i have to tried it as it is simple
    i tried to do but it refused can some one see were i dit wrong in the reset?
    or try t reset it for me so i can see were did wrong?
    thks in advance
    here are de files
    please help mates
    gwee's Avatar
    Dec 2012
    unknown
    your reset is good
    maybe key problem
    thanks my friend but i got 3 keys the car only bips like it is programmed then nothing i will check for for error on ECM
    Dec 2013
    Africa
    Hey Mate
    your remote Serial may be wrong.yaris comes 2 types of remote serial just open the remote Cover and see the Serial 271451-0091 and 271451-0500. which Serial have you tried. if the 271451-0500 then tried 0091. it should be work.
    karachi,pakistan
    0500 is corolla axio yaris vitz 0091
    Quote Originally Posted by gwee View Post
    your reset is good
    maybe key problem
    HELLO MASTER SOME ONE SEND ME A RESET FILES FOR THIS CARS ARE THEY FINE BECOUSE THEY ARE FDIFERENT FROM MINES
    THE CAR IS FAR SO I WOULD LIKE TO BE SURE BEFORE I GO THERE
    SORRY TO DISTRURB YOU
    gwee's Avatar
    Dec 2012
    unknown
    if the car is far, make sure you have internet connection
    will help u via skype if needed
    Default here is the files
    i have thye files here can you compare them
    gwee's Avatar
    Dec 2012
    unknown
    Quote Originally Posted by mvtamele View Post
    smart reset is same
    id code reset, esl sync code was deleted
